Gravitational acceleration and the baryon distribution
The discussion centers on the relationship between gravitational acceleration and baryon distribution in galaxies, particularly in light of a paper suggesting that galaxy rotation can be explained without invoking dark matter. The scope includes theoretical implications, observational data, and alternative models in cosmology.
  • Some participants reference a paper claiming that the rotation curves of galaxies can be predicted from the distribution of visible matter, without requiring dark matter, although this does not imply the end of dark matter theories.
  • Others argue that the correlation between baryon distribution and dark matter distribution is plausible, suggesting that modified gravity theories could also account for the observations.
  • One participant expresses skepticism about the implications of the findings, noting that the data contradicts the traditional view of dark matter as a halo surrounding galaxies.
  • Another participant mentions the need for further exploration of how the findings align with existing dark matter theories and other cosmological observations, indicating that the implications are not yet fully understood.
  • A later reply points out that the findings do not address cosmic microwave background (CMB) data that currently supports dark matter theories.
Participants express a range of views, with no consensus on the implications of the discussed paper. Some find the results surprising and potentially significant, while others maintain that dark matter remains a necessary component of cosmological models.
The discussion highlights limitations in understanding the implications of the findings, particularly regarding their compatibility with established dark matter evidence and other cosmological phenomena.
member 342489
<<Mentor note: Moved from this thread>>
I read this article
http://thedaily.case.edu/rotating-g...cisely-determines-gravitational-acceleration/
It claims that the rotation of galaxies can be explained without a need for dark matter. I not an educated physicist, so I have a hard time judging if this is right or even relevant to this tread.
The have tried to find a PDF on arxiv to support the article. Guess it must be this one...
https://arxiv.org/abs/1609.05917
If this means the end of dark matter, this discussion seems irrelevant, but then again I really don't know :-)
If this post is not relevant, feel free to delete it :-)
Astronomy news on Phys.org
Brian E said:
I read this article
After going through the paper, it certainly does not mean the end of dark matter. What the paper says is that they can accurately predict the rotation curve from the distribution of the visible matter, not that this prediction is based on standard gravity. The authors state this quite clearly in the abstract.
What it would mean in the dark matter paradigm is that the distribution of baryons would be correlated with the distribution of dark matter. To me this does not sound too far fetched. Of course, alternative theories like modified gravity could also reproduce this.
It should be noted that rotational curves are not theonly observation currently associated with dark matter.
Thank you for clarifying this for me. :-)
Sorry, my age takes its toll and this headline reminds me of the EMP (Einstein's Mach Principle),
which in general says that all masses in the universe are dependent on each other and are the
reason for inertia - recently partially confirmed by the sophisticated experiments "Gravity Probe"
(http://www.nasa.gov/mission_pages/gpb/ ), which verified the effects
of Thirring-Lense (frame dragging) and the geodetic precession, e.g. here:
"Gravity Probe B: Final Results of a Space Experiment to Test General Relativity
C. W. F. Everitt et al., Phys. Rev. Lett. 106, 221101 – Published 31 May 2011"
and here:
https://einstein.stanford.edu/RESOURCES/KACST.html
So, if these tiny effects, measured in the orbit of the earth, applicated to the majestic rotating
masses of any galaxy, would, I'm convinced* of, result in a satisfying solution of the
"Dark Matter" conundrum without the need of speculative assumptions of unknown particles
(*sorry, I did not yet tried to do some estimate calculations by myself, but may be someone else
will do it with a prospect of a participitation of a Nobel Prize :biggrin: together with C. W. F. Everitt).
What a pity that the EMP was abandoned so quite early, still in the 1930s by Einstein himself, due
to the overwhelming persuavive power of the redshift interpretation as an expansion of nearly all
of the controlling astronomers at that time. May be not the introduction of the cosmological
constant λ was Einstein's "biggest blunder" but the drop of the EMP and with it his very own
stationary and closed universe, finite, but without limits.
Yes, I also read the paper, and tried to start a separate thread about it in the cosmology forum that mods redirected to here. I appreciate the comment from @Orodruin above because as (yet another) lay person I don't trust my own reading of such things for sharing. But in this case my reading was similar: the data show that the distribution of the "missing" (non-baryonic, "dark") mass is uncannily similar to the distribution of the ordinary matter (stars and gas).
I think this result is quite unexpected. Here are a few informal ways of stating that: first, you know those pop science illustrations showing the gauzy halo of dark matter around the normal matter of a galaxy? You won't be seeing those anymore - ruled out by this data. Second, this data is equivalent to saying that on a galactic scale, every atom of ordinary matter is behaving exactly as if it has too much mass. Or equivalently, on a galactic scale, the law of gravitation is different, but in way that is not the same as MOND or MOG or other prior efforts, and that is not seen at smaller scales like the solar system nor at much larger scales like the matter distribution of the entire observable universe.
Finally, as @Orodruin points out, there are many reasons for belief in dark matter. The question is whether behavior of the dark matter described in this paper turns out to be consistent with the requirements of the other places that dark matter has been "plugged in" to either existing physical theory or new hypotheses. The head-scratching required to answer this question will take some time so the answer presumably isn't known yet. But it will be fascinating to watch the consequences.
It does not explain CMB data favoring DM so far as I can see.
  • · Replies 24 ·
  • · Replies 72 ·
12K
