Gravitational Acceleration given mass and radius
To calculate gravitational acceleration on a planet with five times Earth's mass and twice its radius, the formula GM/r^2 is used. The gravitational acceleration on Earth is approximately 9.8 m/s². By adjusting for the new mass and radius, the gravitational acceleration can be derived without needing to recalculate constants. The increase in mass will increase gravitational acceleration, while the increase in radius will decrease it. Ultimately, the problem can be simplified by applying these adjustments to Earth's known gravitational acceleration.
EliteCodexer
If you lived on a planet with five times the mass of Earth and twice the radius, what would be the gravitational acceleration at the surface of your planet?
GM/r^2
Mass of Earth = 6.00*10^24 kg
Radius of Earth = 6.38*10^3 km
So, when I started out doing this, I quickly plugged in Earth's radius (in m), mass (in kg) and the gravitational constant just to make sure it came out at 9.8 because I know that's what Earth's gravitational acceleration from the surface is, but none of the answer I get are even close. I can't even get this right and I still have to do the actual problem (using 5x the mass and 2x the radius).
GM/r^2
Instead of making us guess where you went wrong, how about posting your work?
it does work. we did it the other day sitting around.
try
GM/r^2
Mass of Earth ≈ 5.97*10^24 kg
Radius of Earth ≈ 6.38*10^3 KM = 6.38*10^6 m
G≈ 6.67 × 10^-11
\frac{M_{earth}}{r_{earth}^2}G ≈ \frac{5.97*10^{24}}{6.38*10^{12}}*6.67*10^{-11}
=\frac{5.97*6.67*10}{6.38} ≈9.805
It's worth persevering to get that right, but you don't need it for this question.
You can solve it just by taking g = 9.8m/s2 for Earth and adjusting it. What effect will 5 times the mass have on that? What effect will twice the radius have?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
