Gravitational DE(?) from Schwartzschild spacetime
The discussion centers on the interpretation of the relationship between the time dilation factor, represented as ##\frac{dt}{dτ}##, and energy in the context of Schwarzschild spacetime. The user initially posits that ##\frac{dt}{dτ}=\frac{E}{mc^2}## is correct, but the consensus clarifies that the textbook's formulation, ##(1-\frac{r_S}{r})\frac{dt}{dτ}=\frac{E}{mc^2}##, is accurate. This distinction arises from the differing definitions of energy: the user refers to energy as measured by a local observer, while the textbook refers to "energy at infinity," which is a conserved quantity in this spacetime geometry.
  • Understanding of Schwarzschild metric and its implications in general relativity.
  • Familiarity with the concepts of four-velocity and four-momentum in relativistic physics.
  • Knowledge of the Euler-Lagrange equation and its application in classical mechanics.
  • Basic grasp of energy conservation principles in curved spacetime.
  • Study the derivation and implications of the Schwarzschild metric in general relativity.
  • Learn about the concept of "energy at infinity" and its significance in gravitational physics.
  • Explore the differences between local and global energy measurements in relativistic contexts.
  • Investigate the application of the Euler-Lagrange equation in various physical systems, particularly in curved spacetime.
Students and researchers in theoretical physics, particularly those focusing on general relativity, gravitational physics, and the dynamics of objects in curved spacetime.
cozycoz
Imagining that an object spining around a spherical mass M has angular momentum that has z-component(θ=0) only, then
$$g_{μν}\frac{dx^μ}{dτ}\frac{dx^ν}{dτ}=(1-\frac{r_s}{r})c^2(\frac{dt}{dτ})^2-\frac{1}{1-\frac{r_s}{r}}(\frac{dr}{dτ})^2-r^2(\frac{dθ}{dτ})^2-r^2\sin^2θ(\frac{dφ}{dτ})^2=c^2$$
becomes
$$(1-\frac{r_s}{r})c^2(\frac{dt}{dτ})^2-\frac{1}{1-\frac{r_s}{r}}(\frac{dr}{dτ})^2-r^2(\frac{dφ}{dτ})^2=c^2.$$
(because the object's path follows ##θ=\frac{π}{2}## and ##\frac{dθ}{dτ}=0##.)According to my professor, by calculus of variation,
$$δ\int ds=δ∫\sqrt{g_{μν}\frac{dx^μ}{dτ}\frac{dx^ν}{dτ}}=0.$$
and if we define ##g_{μν}\frac{dx^μ}{dτ}\frac{dx^ν}{dτ}=c^2≡2T##,
$$δs=δ\int{\sqrt{2T}dτ}=\int{\frac{δT}{\sqrt{2T}}dτ}=\frac{1}{c^2}\int{δT}dτ=0.$$
Therefore, by Euler-Lagrange Equation ##\frac{d}{dτ}(\frac{∂T}{∂\dot{x_μ}})-\frac{∂T}{∂x^μ}=0##, with ##μ=0## we get
$$(1-\frac{r_S}{r})\frac{dt}{dτ}=const.$$So, here goes my question finally.
By multiplying ##mc## to ##\frac{dt}{dτ}##,
$$mc\frac{dt}{dτ}=m\frac{d(ct)}{dτ}=m\frac{dx^0}{dτ}=mU^0=P^0=\frac{E}{c}$$(##U^0## represents four-velocity and ##P^0## four-momentum)
so if we compare the first and the last term, ##\frac{dt}{dτ}=\frac{E}{mc^2}## is the result that I think is correct. But my textbook tells ##(1-\frac{r_S}{r})\frac{dt}{dτ}=\frac{E}{mc^2}##.
If I use ##\frac{dt}{dτ}=\frac{E}{mc^2}##, I get differential equation below:
$$(\frac{dr}{dτ})^2+\frac{J^2}{m^2r^2}(1-\frac{r_S}{r})-\frac{2GM}{r}=c^2[(1-\frac{r_S}{r})^2(\frac{E}{mc^2})^2-1],$$
but using ##(1-\frac{r_S}{r})\frac{dt}{dτ}=\frac{E}{mc^2}##, I get
$$(\frac{dr}{dτ})^2+\frac{J^2}{m^2r^2}(1-\frac{r_S}{r})-\frac{2GM}{r}=c^2[(\frac{E}{mc^2})^2-1].$$
Could you tell me why ##\frac{dt}{dτ}=\frac{E}{mc^2}## is not correct? Thanks!
cozycoz said:
Therefore, by Euler-Lagrange Equation ##\frac{d}{dτ}(\frac{∂T}{∂\dot{x_μ}})-\frac{∂T}{∂x^μ}=0##, with μ=0 we get
Yes. This constant is usually called "energy at infinity" (more precisely it would be "energy per unit mass at infinity"). There is also another constant of the motion, since the metric is also independent of ##\varphi##.
cozycoz said:
if we compare the first and the last term, ##\frac{dt}{dτ}=\frac{E}{mc^2}## is the result that I think is correct. But my textbook tells## (1-\frac{r_S}{r})\frac{dt}{dτ}=\frac{E}{mc^2}##.
That's because your textbook is using ##E## to mean "energy at infinity" (and then dividing by the rest mass to get "energy per unit mass at infinity", as I said above). But you are using ##E## to mean "energy as measured by an observer momentarily at rest with respect to the object". Those are two different things, and only the first one (the one your textbook is using ##E## to mean) is a constant of the motion.
Oh I totally got it. Thanks a lot!
  • · Replies 43 ·
  • · Replies 30 ·
  • · Replies 17 ·
