Gravitational Energy by breaking down volcanoes / mountains?
The discussion explores innovative ideas for harnessing gravitational energy beyond traditional hydroelectric methods. Suggestions include creating artificial water courses in high-altitude areas to optimize energy production and using solar mirrors to accelerate snowmelt from mountains like the Himalayas. Another concept involves constructing ramps on mountains to utilize soil and rock as energy sources, although concerns about sustainability and practicality are raised. Additionally, the potential of using active volcanoes to generate energy is considered, but this poses risks to the geological stability of the volcanoes themselves. Overall, while these ideas present intriguing possibilities, they face significant practical and environmental challenges.
Gerinski
For centuries we have been using the gravitational potential energy of water courses by building watermills and dams with hydroelectric plants. The weather does the job of bringing the water back 'upstairs' for free so conceptually that's a wonderful energy source. The problem is (I guess) that we have far too few convenient water courses to produce the required energy output.
From here, several ideas arise:
1) what about building artificial convenient water courses? Study were there is a lot of precipitation on high altitude areas, in geographically convenient areas (altitude gradients etc) and build huge water lakes to be used for hydroelectric energy production (rather than just using naturally occurring water courses).
2) force / accelerate the water flow by melting the snow from very high permanently snowed mountains such as the Himalayas, for example using solar mirrors to warm up the snow. I guess that this would not alter the natural equilibrium significantly, since the cold and new snow precipitations would restore the melted snow?
3) what about using mountains and their soil / rocks instead of water? Very simply stated, imagine we build a huge ramp from the top of a mountain to the deepest point in a sensibly close distance. Then we put a bulldozer on the top of the mountain which gradually breaks down the stuff at the top of the mountain and throws it into the ramp, where it would fall and could be used similarly as water to power some kind of turbines.
4) of course that would have no natural mechanism bringing the stuff back to high altitude (unless we wait millions of years for mountain rising), but volcanoes do naturally raise 'stuff' from the Earth up. If a similar system would be placed near the top of an active volcano, just far enough from the erupting crater to avoid the whole thing getting melted, that could also be a possibility.
Probably crazy?
If you think building a dam is expensive, try building a river instead.
It doesn't really matter that much where the hydropower is generated. That's why electricity is so convenient: the power generated in a plant can be transmitted thru power lines for great distances, so everyone doesn't have to build a power plant or dam in their backyard.
The top of a mountain is a pretty difficult place to install a bunch of mirrors. And the weather there is not always sunny and clear.
And what do you do when all the mountains are laid flat? Not to mention that avalanches are hard to extract energy from without wrecking your machinery.
Probably crazy?
The only problem with the volcano approach is that all that rock and stuff is what keeps the lava, you know, in the volcano in the first place. Once you take the mountain away, the lava flows out and cools, and there's no more volcano, at least not for a long time.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
