Does Gravitational Field Flux Cause Gravitational Waves?
The discussion explores the potential relationship between gravitational field flux and the generation of gravitational waves, drawing parallels to how changing electric fields create magnetic fields. While some analogous effects exist, they are not exact, as gravitational fields are fundamentally different from electromagnetic fields. The gravitational field is described by the Riemann curvature tensor, which has multiple components, unlike the simpler structure of electromagnetic fields. Gravitational waves are identified as oscillations within the Weyl curvature, suggesting a complex interaction within gravitational fields. Overall, the conversation highlights the nuanced distinctions between gravitational and electromagnetic phenomena.
Saksham Dhull
As most of know that magnetic field arises due to change in electric field flux over a surface.
In the same way, is there any kind of field arising due to gravitational field flux about a surface ?
And if yes then does gravitational field and that field cause each other (in the same way electric field and magnetic fields do)?
I believe there are some analogous effects, but not exactly. Have a look at this wiki article*: https://en.wikipedia.org/wiki/Gravitoelectromagnetism
As the article states in the first paragraph, these are analogies and approximations that are only valid in certain situations. There is still only one gravitational field, just like there is only one electromagnetic field (the electric and magnetic components are joined into a single field). I've never heard of the gravitational field being split into multiple components, so I assume the analogies and approximations are not that useful in most cases where we do calculations involving gravity.
*This article's reliability is questionable, as it is lacking valid references in many areas.
The gravitational field is described by the Riemann curvature tensor, which has 20 components. (In contrast, the electromagnetic field has 6 independent components.) You can break down the Riemann curvature tensor into smaller parts. See https://en.wikipedia.org/wiki/Ricci_decomposition
One of the parts is the Weyl curvature. There are gravitational waves which are oscillations in the Weyl curvature.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
