Gravitational Force on 0.64 kg Sphere in Space Shuttle
The gravitational force on a 0.64 kg sphere inside the space shuttle, which orbits 396.9 km above Earth's surface, can be calculated using the formula F = (G * M * m) / r^2. Given the mass of Earth (5.98 x 10^24 kg) and the radius of Earth (6.37 x 10^6 m), the correct distance (r) from the center of the Earth to the sphere is 6.37 x 10^6 m + 396.9 x 10^3 m, resulting in a gravitational force of approximately 5.57 N. The discussion highlights the importance of correctly defining the distance r as the total distance from the Earth's center to the object.
  • Understanding of Newton's Law of Universal Gravitation
  • Familiarity with gravitational constant (G)
  • Knowledge of mass and radius of Earth
  • Basic algebra for unit conversion and calculations
  • Review the derivation of Newton's Law of Universal Gravitation
  • Learn about gravitational force calculations in different orbits
  • Explore the implications of gravitational force on objects in microgravity
  • Study unit conversion techniques for physics problems
Students studying physics, aerospace engineers, and anyone interested in gravitational effects on objects in space.
nweis84
I have this problem i have been trying to solve and can't seem to get it right. The question states:
The space shuttle is in orbit 396.9 km above the surface of the earth. What is the gravitational force on a 0.64 kg sphere inside the space shuttle?
mass Earth = 5.98x10^24 kg
radius of Earth = 6.37x10^6 m
I've tried using the equation F= (G*M*m)/r^2 and the answer i got was about 5.57 N
for the distance above Earth i converted the units and added them to the Earth's radius so I'm not sure what I could be doing wrong.
is it possible that i am using the wrong equation all together?
r is defined as being the distance between the two point masses.
I might be wrong, but for this problem, would you not just use the distance from Earth as r?
F = GMm/r^2 , G is the universal gravity, M is mass of the object acting the force,
m is the mass of the object that the force is acted upon, r is the distance between the center of the Earth and the center of the object in space.
  • · Replies 18 ·
