How Much Gravitational Force Acts Between an Astronaut and a Space Shuttle?
The gravitational force between a 61 kg astronaut and a 71,000 kg space shuttle, when 81 m apart, is calculated using the formula F = [G(Mm)/r^2]. Initial calculations yielded 48.4 nN, but this was based on an incorrect distance of 84 m. Correcting the distance to 81 m results in a force of approximately 4.40 nN. The discussion emphasizes the importance of using the correct distance in gravitational force calculations. Accurate arithmetic is crucial for obtaining the correct answer.
Finhum
What is the approximate value of the gravitational force between a 61 kg astronaut and a 71000 kg space shuttle when they're 81 m apart?
F = [G(Mm)/r^2]
F = (6.67×10−11 N·m2/kg2)(61 kg)(71,000 kg)÷
(84 m)2 = 48.4 nN.
Web assign marked it wrong?
Is it wrong?
Check your arithmetic, given your set up (which is correct) I get 40.9 nN.
^ That is wrong.
Whoops, I just checked what you had filled in the equation as. The problem you wrote says that the shuttle and the astronaut are 81 m apart, but the set-up shows 84 m. My bad.
Using 81 m as the distance, I get 4.40 nN. Unless, of course, the problem actually is 84.
