Gravitational Force on 0.64 kg Sphere in Space Shuttle
To calculate the gravitational force on a 0.64 kg sphere in a space shuttle orbiting 396.9 km above Earth, the formula F = (G*M*m)/r^2 is appropriate, where G is the gravitational constant, M is Earth's mass, m is the sphere's mass, and r is the distance from the center of Earth to the sphere. The radius r should be the sum of Earth's radius (6.37x10^6 m) and the altitude of the shuttle (396.9 km converted to meters). The calculated gravitational force of approximately 5.57 N suggests a potential miscalculation in the distance used. It's crucial to ensure that r represents the correct total distance from Earth's center to the sphere. Accurate application of the formula will yield the correct gravitational force.
nweis84
I have this problem i have been trying to solve and can't seem to get it right. The question states:
The space shuttle is in orbit 396.9 km above the surface of the earth. What is the gravitational force on a 0.64 kg sphere inside the space shuttle?
mass Earth = 5.98x10^24 kg
radius of Earth = 6.37x10^6 m
I've tried using the equation F= (G*M*m)/r^2 and the answer i got was about 5.57 N
for the distance above Earth i converted the units and added them to the Earth's radius so I'm not sure what I could be doing wrong.
is it possible that i am using the wrong equation all together?
r is defined as being the distance between the two point masses.
I might be wrong, but for this problem, would you not just use the distance from Earth as r?
F = GMm/r^2 , G is the universal gravity, M is mass of the object acting the force,
m is the mass of the object that the force is acted upon, r is the distance between the center of the Earth and the center of the object in space.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
