Gravitational potential energy challenge
The challenge involves designing a device that transports a 305-gram mass over 4 meters using only gravitational potential energy from a falling soup can. The can must fall from a maximum height of 20 cm and land on the device without penetrating it. The device has specific size restrictions and must remain on course while moving in a straight line. A proposed solution involves a lever system where the falling can acts as a fulcrum, propelling the device through a counterweight mechanism. Participants are encouraged to share additional ideas for achieving the challenge's requirements.
p4physics
ok I am in high school and have a physics challenge, its a device that transports a mass of 305 grams (Tomato soup can), a distance of 4 meters. no chemical, elastic, spring, electrical or magnetic energy can be used - the only energy source for propelling the device will come from the gravitational potential energy of the soup can. the soup can can be located no higher than 20 cm above the device itself and it will fall down on the device and we are to come up with some form of mechanism to propel the device once the can falls on it. other restrictions are -
1. device has max dimensions of 30cm X 30cm X 30cm
2. nothing falls off the device. if a part detaches and falls on the ground the distance traveled will be measured from starting point to the part.
3. once the device starts to move, it will be self guided and must travel in a straight line. the course is 1 meter wide and if it goes off course, the distance traveled will be from the starting point to where it first went off course.
4. once the can falls, it must not go lower or into the device. so basically it falls and lands on top of device but doesn't go through it to the ground.
so... if you have any ideas, please post them. thank you!
One possible solution is to use a lever system. The soup can would be placed at the fulcrum of the lever, with the device at one end, and a counterweight at the other. When the soup can falls, it will cause the lever to pivot, pushing the counterweight in one direction and the device in the other. By adjusting the weight of the counterweight and the length of the lever arm, you can create enough force to propel the device the desired distance.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
