Gravitational pull of Earth and Moon on spaceship
The discussion focuses on determining the distance from Earth at which the Moon's gravitational pull on a spaceship exceeds that of Earth. The gravitational forces are calculated using the formula F = Gm1m2/r², with the mass of the Earth and Moon provided. The radius from Earth to the Moon is calculated as 2.24 x 10^6 km, and the Moon's gravitational pull is found to be 1.618 m/s². Participants are encouraged to set up equations for the gravitational forces from both Earth and the Moon in relation to the distance X from Earth's center. The solution requires equating these forces to find the specific distance where the Moon's influence becomes stronger.
mckayl2
A spaceship is launched and starts moving directly towards the Moon. At what distance from the Earth will the pull of the Moon on the spaceship exceed the pull of the Earth? Ignore the effect of the Sun in this calculation.
F = Gm1m2/r2
F = ma = mg
g=9.80m/s2
Mass of Earth = 5.86 x 1024
Mass of moon = 7.35 x 1022
For the earth:
Using F=mg=Gm1m2/r2, radius of Earth to Moon is calculated to be 2.24 x 106km
For the moon:
Using mg = Gm1m2/r2, the gravitational pull of the moon is calculated to be 1.618m/s2
I'm not sure where to go from here, any help is much appreciated :)
Hint: If the spaceship is a distance X from the center of the earth, how far is it from the center of the moon? If you call the mass of the spaceship m, what's the Earth's gravitational force on the ship in terms of X? What's the moon's gravitational force? Set up an equation and solve for X.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
