The Role of Gravity in Star and Planet Formation
Gravity plays a crucial role in the equilibrium of stars by balancing the outward pressure from nuclear fusion against the inward pull of gravity. This fusion process begins when a star accumulates enough mass, leading to the fusion of hydrogen into heavier elements, which generates heat. As stars lose mass over time, gravity's ability to maintain stability diminishes, potentially resulting in phenomena such as novas or supernovas. Additionally, gravity is essential in the formation of planets, as it causes dust and gas in protoplanetary disks to coalesce into larger bodies. Overall, gravity is fundamental in both star stability and the formation of planetary systems.
qplazmgg
can u help me to explain the role of gravity in the equilibrium of stars in their production of enegry , and an explanation of the role of gravity in the formation of planets.
thankssssssss
quick and dirty answer
Basically stars are converting hydrogen into heavier elements (a process known as fusion), which released heat in the process. This heat attempts to make the star expand, which is held in check by the immense force of gravity.
A couple things to note:
1) It is gravity that is responsible for starting the fusion process. The stars accrete matter until they have a critical mass, at which point the gravitational force acting on the atoms causes them to undergo fusion.
2) As the star "burns" (it is not on fire, fire requires oxygen) it loses mass. This reduction in mass means that, over time, the gravitational force will not be enough to hold the star together. At that point we get a fireworks display known as a nova, or if the star is large enough, a supernova.
Please do not double post - this question was posed yesterday. One should search for missing posts before reposting.
As for fusion - it's the temperature (or kinetic energy) of the nuclei that control the fusion reaction rate. Gravity holds it together.
