Determining Maximum Height of a Projectile Shot Upward from Earth
In summary, the projectile shot up from the Earth's surface traveling at a speed of 1.40x10^4. The height it reaches is unknown, but it is likely high enough that it reaches the top of the atmosphere.
splac6996
37
A projectile is shot straight up from the Earth's surface at a speed of 1.40×10^4 . How high does it go?
potential energy is given by (GM(1)M(2))/R
I attempted to solve this using energy conservation equation and solving for r which I thought would be the radius of the Earth plus the distance traveled by the projectile. By subtracting the radius I thought I would get the distance traveled but my answer is wrong can someone help please
What units is that speed in?
It might be of help to a reader who is going to assist you if you would show the actual calculation you did.
There are a number of things you could have done wrong. For example, did you remember to use a negative sign in your potential? Do you have an initial potential, where did you define your zero in potential energy to be? Specifically, what was the equation you used?
the speed is defined in km/hr and for the formula that i used I did use a negative sign for my potential energy and I used my zero point to be the point were the projectile is shot from.
Why not just use m.g.h=1/2mv^2?
And potential energy is in Joule not in Newton.
mgh is only applicable near the Earth's surface. For this projectile it will be traveling significantly far away from the Earth's surface to make mgh non-applicable.
Well my understanding is that if the distance is smaller than than the radius then I could use mgh=1/2mv^2 but in this case since the height is going to be largerthan the radius of the Earth so my answer would be wrong.
use v^2=u^2+2as,
your deceleration is not constant in the equation. The deceleration is given as the average deceleration the object undergo in that motion. to find the average deceleration,
integrate the below equation with respect to distance, with the radius of the Earth as the lower limit and the radius+height of the Earth as the upper limit.
then divide by the height to find the average deceleration.
a=Gm/r^2
EDIT: Well, you will need to have the radius of the Earth to solve the equation. Even after simplifying expressions of the radius of the Earth into g.
@splac6996: Well, If you take zero of your PE at surface of the Earth, your formula for PE at R (in #1 post) is not correct.
this is what i think
-GM(earth)m(projectile)/H(radius of Earth + distance traveled)=(1/2)m(projectile)v^2
doing the algebra and simplifying i have
H=-2GM/v^2
is that correct
Nope. You can see, if you put distance traveled = 0 your
RHS = 0 but LHS is not = 0.
the expression for the potential -GM(earth)m(projectile)/H(radius of Earth + distance traveled) gives you the potential energy at the highest point. You will still need to minus the potential at the Earth's radius.
With gravitational force [itex]F= -GMm/r^2[/itex], the potential energy is [itex]GMm/r[/itex] but that has 0 point at infinity, not at the surface of the earth.
Can you show the exact figures you got?
1. What is the formula for calculating the maximum height of a projectile?
The formula for calculating the maximum height of a projectile shot upward from Earth is: h = (v02 * sin2(θ))/2g, where h is the maximum height, v0 is the initial velocity, θ is the angle of launch, and g is the acceleration due to gravity.
2. How do you determine the initial velocity of a projectile?
The initial velocity of a projectile can be determined by using a device such as a radar gun or by measuring the distance and time it takes for the projectile to reach its maximum height. The formula to calculate initial velocity is: v0 = √(2gh)/sin(θ), where h is the maximum height, g is the acceleration due to gravity, and θ is the angle of launch.
3. What factors can affect the maximum height of a projectile?
The maximum height of a projectile can be affected by factors such as the initial velocity, angle of launch, air resistance, and the acceleration due to gravity. Other factors that can affect the maximum height include the mass and shape of the projectile, as well as external forces such as wind.
4. Can the maximum height of a projectile be greater than the initial height?
Yes, the maximum height of a projectile can be greater than the initial height. This is possible when the angle of launch is greater than 45 degrees, as the vertical component of the initial velocity will be larger than the horizontal component, allowing the projectile to reach a greater height before falling back down.
5. How can the maximum height of a projectile be affected by the mass of the projectile?
The mass of a projectile can affect its maximum height by changing the initial velocity. A heavier projectile will require a greater initial velocity to reach the same maximum height as a lighter projectile. However, if the initial velocity is kept constant, the mass of the projectile will not affect its maximum height.
21K
