Measuring Gravity: Finding Accurate Results for Your City
The acceleration due to gravity varies by location due to factors like altitude and Earth's crust density. To find the accurate value for a specific city, it's recommended to consult local government or university physics departments for precise measurements. Online databases can also provide gravitational data, but it's essential to verify the reliability of these sources. Including the percent error in your analysis is important, as the accepted value may not reflect the actual value for your area. Accurate data will enhance the quality of your physics lab report.
Meab5
Hello In my physics class we have just completed a lab on measuring the acceleration due to gravity. For my analysis I wanted to include that there was a percent error because the accepted value is not necessarilly the actual value for my city. Does anyone know where I can find the actual value for acceleration due to Gravity for my city.
Any help would be apreciated
Thanks
This should help you estimate it:
http://www.mines.edu/fs_home/tboyd/GP311/MODULES/GRAV/NOTES/latitude.html
Hello! That's a great question. The accepted value for the acceleration due to gravity can vary slightly depending on location, as it is affected by factors such as altitude and the density of the Earth's crust. To find the most accurate value for your city, I would recommend checking with your local government or university's physics department. They may have specific measurements or calculations for your area. Additionally, you can also search for online databases or resources that provide gravitational data for different locations. Just be sure to double-check the reliability and accuracy of the source. Best of luck with your analysis!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
