Greater change in momentum between two objects
In a collision between two objects, the change in momentum for both objects is equal due to the same force acting on them for the same duration, resulting in identical impulse. However, the change in kinetic energy differs because it is influenced by both mass and velocity, with kinetic energy being quadratic in speed and linear in mass. The differing masses of the objects lead to different velocity changes, affecting their kinetic energy post-collision. Calculating the ratios of kinetic energy before and after the collision reveals how these ratios depend on the mass and velocity of each object. Understanding the definitions and equations for impulse, momentum, and kinetic energy is crucial for accurate analysis.
positron
When two objects collide, how do you determine which object experiences the greater change in momentum? for instance, if A and B with different masses traveling at different speeds collide, do they experience the same momentum change after the collision? What about KE?
This is my reasoning so far:
The change in momentum does not change, because the same force acts on both A and B for the same amount of time during the collision. However, the kinetic change because the masses of the objects are different even though the change in velocities are the same. Is this correct?
You've correctly noted that the same force is acting on both A and B. It will obviously also act for the same amount of time, meaning the impulse imparted to each will be the same, give or take a direction. What is impulse, and what does this tell you about the momentum change for each block? And, if their masses are different, what does this tell you about the velocity change for each block?
Once you have that, consider that kinetic energy is linear in mass but quadratic in speed - what does that tell you about the change in kinetic energy for each block? It might be a good time here to write a few equations and calculate the ratios of the kinetic energy for each block before and after the collision. What do those ratios depend on?
Bottom line: You're making a couple of bad assumptions, but apart from those your reasoning isn't bad. Go back and look at the definition and defining equations for impulse, momentum and kinetic energy.
