Green light
courtrigrad
1,236
At the instant the traffic light turns green, an automobile starts with a constant acceleration [itex] a_{x} [/itex] of 6.0 [itex] \frac{ft}{sec^{2}} [/itex]. At the same instant, a truck traveling with a constant speed of 30 [itex] \frac{ft}{sec} [/itex], overtakes and passes the automobile. (a) How far beyond the starting point will the automobile overtake the truck? (b) How fast will the car be traveling at that instant?
(a) So as time increases the speed of the first car increases while the speed of the second car stays constant. After five seconds the first car is 186 feet from the starting line while the second car is 150 feet from the starting line. Is this correct?
(b) Would the car be traveling 96 ft/sec?
Any feedback is appreciated.
Thanks
Answers and Replies
Doc Al
Mentor
45,447
1,907
True.
How did you conclude this?
Right.
Approach this problem systematically. Can you write equations that describe:
(1) The position of the car (from the starting point) as a function of time?
(2) The position of the truck (from that same point) as a function of time?​
You can set the final positions equal to each other to find the time when the car overtakes the truck. Then you can use that time to find the distance and speed of the car at that point.
courtrigrad
1,236
Ok so I can use [itex] x = x_{0} + v_{x}_{0}t + \frac{1}{2}a_{x}t^{2} [/itex] or [itex] x = 3t^{2} [/itex] (acceleration) and [itex] x = x_{0} + \frac{1}{2}(v_{x}_{0}+v_{x})t [/itex] or [itex] x = 30t [/itex]. So [itex] t = 10 [/itex]. So the car would be 363 feet from starting line traveling at 66 ft/sec.
Is this correct?
Fermat
872
I'm afraid not :(
What did you get for the time ?
Sorry - you got 10 s - that's correct.
So what is the distance traveled ??
courtrigrad
1,236
363 feet for car and 330 feet for truck
Fermat
872
you have x = 3t²
if t = 10 then x = 3*10² = 3*100 = 300 ft.
Doc Al
Mentor
45,447
1,907
Exactly right for the car.
No need to find the average speed of the truck, since its speed is constant. But correct nonetheless.
Right.
Realize that you found the time by setting the distances equal; so if you calculate different distances for car and truck--something must be wrong!
But the car starts from rest, not at 66 ft/sec. (That's why [itex] x = 3t^{2} [/itex]; the initial speed is zero.)
courtrigrad
1,236
no but don't you have to go to x = 11? Because at x = 10, the two vehicles are at the same position. The question asked the distance from the starting line when the car overtakes the truck.
is this corrrect?
thanks
Fermat
872
the two vehicles are at the same position at x = 0. This is where the traffic lights are, i.e the starting line.
How did you get x = 10, or 11?
courtrigrad
1,236
I meant t = 11
Doc Al
Mentor
45,447
1,907
To solve the problem, you have to pretend that the point where they are at the same position is the point where the car overtakes the truck.
But I think I know what you're thinking... that until the body of the car passes the front of the truck, it hasn't really overtaken it. If that's what you think, good for you! But since you have no idea how big the car is, you have to pretend they are points! :smile: (And get used to problems being poorly worded.)
In any case, why x = 11? (Do you mean t = 11?) That's just a guess--never a good idea.
courtrigrad
1,236
I used [itex] v_{x}^{2} = v_{x}_{0}^{2} + 2a_{x}(x-x_{0}) [/itex] and [itex] v_{x} = 66 ft/sec [/itex]
Doc Al
Mentor
45,447
1,907
Find the speed that the car is traveling at the moment it passes the truck. (Which is at t = 10 sec, not t =11.) And recalculate the distances as Fermat suggests.
Suggested for: Green light
  • Last Post
  • Last Post
