Calculating Magnetic Dipole Moment of a Sphere
In summary, the question discusses the magnetic dipole moment of a uniformly charged solid sphere set spinning with angular velocity. The attempted solution involves using the magnetic dipole moment of a disk, but with the charge density (\sigma) replaced by 3Q/(4 \pi R^3). However, this does not give the correct answer. The correct integral is (- \int_0^{\pi} ( \rho R \sin \theta d\theta) ((1/4) R^4 \sin^4 \theta \pi \omega)).
ehrenfest
2,020
[SOLVED] Griffiths 5.58
A uniformly charged solid sphere of radius R carries a total charge Q, and is set spinning with angular velocity \omega.
What is the magnetic dipole moment of the sphere.
The magnetic dipole moment of a disk is
[tex](1/4) r^4 \sigma \pi \omega[/tex]
Why does
[tex]\int_0^{\pi} (Rd\theta) ((1/4) R^4 \sin^4 \theta \sigma \pi \omega)[/tex]
with [itex]\sigma[/itex] replaced by [itex]3Q/(4 \pi R^3)[/itex] not give the correct answer?
I'd imagine that the sigma in the dipole moment of a disk is a charge density per area.
So what is \sigma replaced with here? How do I get the moment for a solid sphere from the moment for a disk?
The analogous idea worked to get the moment of a disk from the moment of a ring which is kind of confusing!
There's nothing wrong with the idea. Here's a hint: each disc contains dz * \rho charge, where \rho is the charge per unit volume.
isn't dz = Rd\theta ?
No. Try [tex]r \sin \theta\,d\theta[/tex]
[tex]z = R\cos \theta [/tex] so [tex] dz = - R \sin \theta d\theta[/tex] so the correct integral is
[tex]
= - \int_0^{\pi} ( \rho R \sin \theta d\theta) ((1/4) R^4 \sin^4 \theta \pi \omega)
[/tex]
right?
Related to Calculating Magnetic Dipole Moment of a Sphere
1. What is the formula for calculating the magnetic dipole moment of a sphere?
The formula for calculating the magnetic dipole moment of a sphere is M = χV, where M is the magnetic moment, χ is the magnetic susceptibility, and V is the volume of the sphere.
2. What is the SI unit of magnetic dipole moment?
The SI unit of magnetic dipole moment is ampere-square meters (A·m²).
3. How does the magnetic dipole moment of a sphere differ from that of a bar magnet?
The magnetic dipole moment of a sphere is a vector quantity, while the magnetic dipole moment of a bar magnet is a scalar quantity. Additionally, the magnetic dipole moment of a sphere is calculated based on its volume and magnetic susceptibility, while the magnetic dipole moment of a bar magnet is based on its length, width, and magnetic field strength.
4. Can the magnetic dipole moment of a sphere be negative?
Yes, the magnetic dipole moment of a sphere can be negative if the magnetic susceptibility is negative. This indicates that the sphere has a net magnetic moment in the opposite direction of an applied magnetic field.
5. How can the magnetic dipole moment of a sphere be experimentally determined?
The magnetic dipole moment of a sphere can be experimentally determined by measuring the deflection of the sphere in a known magnetic field. By knowing the strength of the magnetic field, the magnetic susceptibility, and the geometry of the sphere, the magnetic dipole moment can be calculated.
