Why is G abelian if |G/Z(G)|=p with p prime?
Menelaus
I am aware of the theorem |G/Z(G)|=p with p prime implies G/Z(G) is cyclic and thus G is abelian, but I do not understand why. Is there not a theorem that says G abelian \Leftrightarrow Z(G)=G? So what if |G|=p^{3} and |Z(G)|=p^{2}? This implies |G/Z(G)|=p implying G is abelian however G\neqZ(G). What is the ambiguity here?
There is no ambiguity. The situation you mention can just never occur. You have just proven that it can never oocur that |G|=p3 and |Z(G)|=p2.
You can use this, for example to prove that all groups of order p2 are abelian. Indeed, Z(G) is a subgroup of G, so there are three possibilities:
  • |Z(G)|=1 It can be proven that this can never happen (a group with prime order must always have nontrivial center)
  • |Z(G)|=p Then your theorem says the group is abelian, thus |Z(G)|=p2, which is a contradiction.
  • |Z(G)|=p2 is the only remaining possibility.
Ah I see! Thanks for clearing that up.
Try looking at the exact sequence of groups,
0 -> Z(G) -> G -> G/Z(G) -> 1
- Any group of prime order is cyclic so G/Z(G) is cyclic.
- If the sequence is split then the group is isomorphic to the direct product Z(G) x G/Z(G)
so G is abelian and Z(G) = G
- If the sequence is not split what happens?
I do not follow, I don't believe I've ever looked at this sequence or talked about what a split sequence is. Micromass cleared up the problem I was having though.
lavina, do you mean not left-split (because right-splits need not be direct products)?
To me split means that there is an inverse of the projection onto G/Z(G)
Since Z(G) is in the center of the group split means direct product - I think.
What you get is that there is a subgroup isomorphic to G/Z(G) that commutes with every other element of the group. this should be a direct product.
If the sequence is not split then a lift of a generator of the quotient has some power that lies in Z(G) but again it commutes with everything so G is abelian.
I am sorry. I thought he only cleared up a special case. Anyway. This is a different way of looking at the problem that I thought you might find interesting.
ah, so you DID mean right-split. let me assure you that right-split ≠ direct product.
consider the following short exact sequence:
0→Cn→Dn→Dn/Cn→0.
(where we map a generator of Cn, to a generating rotation of Dn).
define:
f:Dn/Cn→Dn by:
f(Cn) = 1
f(Cns) = s
then if p is the canonical projection: p(f(Cnx)) = Cnx.
but Dn is certainly not a direct product of abelian groups.
0→Cn→Dn→Dn/Cn→0.
define:
f:Dn/Cn→Dn by:
f(Cn) = 1
f(Cns) = s
If The kernel is in the center of the group then split means direct product. Otherwise not necessarily.I think the proof is straight forward.
i see how this is true, because if H acts on N by conjugation, and N is in Z(G), the action has to be trivial.
yes. that's it.
