What are some options for H-bridge ICs to power 12V 3.6A loads?
  • Thread starter Thread starter EagleOnePro
    Bridge
For powering a 12V 3.6A load, the L6203 H-bridge IC is recommended, especially when paired with a heatsink for heat management. Alternatives like the L298N are also suggested, with resources available on Sparkfun and Digikey for various motor drivers. Users may need to consider separate MOSFETs and drivers as power requirements increase. A specific option found has a ZIP package with a 1.27 mm pitch, which may complicate breadboard integration. Overall, while options exist, availability of DIP packages may be limited.
EagleOnePro
Hi, I am in the market for an H-bridge IC to power 12V 3.6A through. This is the circuit.
http://fritzing.org/projects/drive-motor-using-l293d-sn754410
Do you know where I could get an H-bridge like the one in the diagram? so I can power a bigger load and use 12V 3.6A. I seriously Googled this like a mad man and I'd like your input.
Even If you tell me to scrap the idea and try a beater method. Thanks
Other than a high power motor shield - try L6203 - be sure to use a heatsink. The chip in your example is an H bridge with driver - as you move up in power the MOSFET and Drivers may become separate - but there should be others similar to the L6203 in this power level.
http://www.st.com/web/catalog/sense_power/FM142/CL851/SC1790
Also Sparkfun has some forum posts on similar items - L298N for example.
Likes 1 person
Try the motor drivers offered by Digikey. You can narrow it down with the filters. I found one that can do what you want but it comes in a ZIP package. That's a 1.27 mm picth which will be hard to get into a breadboard because you'll have to twist the pins a little. There are many more options but I couldn't find a DIP package that is in stock.
Likes 1 person
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
