Understanding H NMR Coupling Constants: Matching J-Values vs. Peak Alignment
In summary, when trying to predict what is coupled to what in a HNMR spectra, it is crucial to consider the j-values and the orientation of the peaks towards each other. In this case, while the chemical shifts of the 7.00ppm H's may seem to match those of the 8.04ppm H's, the j-values and the orientation of the peaks suggest that the 8.04/7.0 and 7.58/7.39 sets are the coupled ones. The fact that their j-values are a little different does not necessarily negate the coupling.
HappMatt
94
background:
I have a HNMR spectra and I am trying to figure out what is coupled to what. There is a set of 4 doublets where it is know that there 2 sets of coupled doublets. the doublets have j-values of 8.8 @ 8.04ppm, 8.8@ 7.58ppm, 8.4@7.39ppm and 8.4@7.00ppm. While I may have assumed that the 8.04/7.58 and the 7.39/7.00 are the coupled sets due to j-values, the peaks do not lean towards each other. on the other hand, the 8.04/7.0 and the 7.58/7.39 set do lean towards each other. In addition appears as though the chemical shift of the 7.00ppm H's is near what i would expect for the H's next to the 8.04ppm H's
Question:
If trying to predict what's coupled to what, is it more important that the j-values match or that the peaks lean towards each other? In addition since the chemical shifts of the 7.0 h's seem's to be near the 8.04 H's on the molecule and the fact that they lean towards each other enough to assume they are coupled, or since their j-values are a little different would that negate them being coupled?
The j-couplings are the more important ones here.
Both the j-values and peak alignment are important factors to consider when trying to determine coupling in an HNMR spectrum. The j-values represent the coupling constant, which is a measure of the strength of the coupling between two nuclei. Matching j-values can provide valuable information about which peaks are coupled to each other. However, peak alignment can also be a useful indicator of coupling. When two peaks are coupled, their intensity will be affected, causing them to lean towards each other. This is known as the "splitting" of the peaks and is a result of the spin-spin coupling between the nuclei. Therefore, it is important to consider both the j-values and peak alignment when trying to determine coupling in an HNMR spectrum.
In regards to the specific example provided, it is possible that the peaks with j-values of 8.04 and 7.00 are coupled, despite their slightly different j-values. It is also possible that the peaks with j-values of 8.8 and 7.58 are coupled, as the peak alignment suggests. The chemical shifts of the peaks can also provide useful information, as you have noted. However, it is important to keep in mind that the chemical shifts can be influenced by other factors such as neighboring functional groups or solvent effects. Therefore, it is best to use a combination of all of these factors to make a confident determination of coupling in an HNMR spectrum. Further analysis, such as COSY or NOESY experiments, may also be helpful in confirming coupling between specific peaks.
What is H NMR coupling constant?
H NMR coupling constant is a measure of the interaction between two adjacent hydrogen atoms in a molecule. It is represented by J value and is measured in Hertz (Hz).
How is H NMR coupling constant determined?
H NMR coupling constant is determined by analyzing the splitting pattern of NMR peaks. The number of peaks in a splitting pattern corresponds to the number of neighboring hydrogen atoms and the spacing between the peaks gives the J value.
What factors affect H NMR coupling constant?
The main factors that affect H NMR coupling constant are the nature of the atoms bonded to the hydrogen atoms, the hybridization of the carbon atom they are attached to, and the electronegativity of neighboring atoms.
What information can be obtained from H NMR coupling constant?
H NMR coupling constant provides information about the connectivity and arrangement of atoms in a molecule. It can also give insights into the electronic properties and molecular symmetry.
What does the magnitude of H NMR coupling constant indicate?
The magnitude of H NMR coupling constant indicates the strength of the interaction between two hydrogen atoms. A larger J value suggests a stronger coupling, while a smaller value indicates a weaker coupling.
  • Quantum Physics
  • Beyond the Standard Models
  • Other Physics Topics
