Calculating Half-Life of Radioactive KCl
To calculate the half-life of radioactive KCl, a 2.71g sample decaying at a rate of 400Bq into isotope 40K, which is 1.17% of normal K, is analyzed. The relevant equations include dn/dt = n * lambda and t-1/2 = 0.693/lambda. The challenge lies in determining the initial quantity (N) for the calculations. Boundary conditions must be established to solve the differential equation effectively. Understanding these parameters is crucial for accurately calculating the half-life of the nuclide.
abrowaqas
2.71g sample of radioactive KCl is decaying at a constant rate of 400Bq into the isotope 40K. which constitutes 1.17% of normal K. calculate the half life of this nuclide.
we have dn/dt = n * lamda and t-1/2 = 0.693/lamda.
how i put the value of N... which is not clear in question
You have a differential equation, so you need to find your boundary conditions
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
