Half Lifes and Critical Conditions
  • Thread starter Thread starter s.p.q.r
    Conditions
Half-lives, particularly in the context of radioactive decay, are generally unaffected by external conditions such as high pressure or temperature. Recent studies indicate that under extreme pressures, there may be slight modifications to half-lives due to increased proximity of atomic nuclei, potentially enhancing the strong nuclear force. The discussion also touches on the distinction between real gases and ideal gases, although the primary focus remains on the behavior of half-lives. Overall, traditional understanding holds that physical conditions do not alter half-lives significantly. This highlights the complexity of nuclear interactions under varying conditions.
s.p.q.r
Hi,
Do half lifes dissapate quicker when under critical conditions, e.g- high pressure, high temprature etc.?
Is there are difference in half life dissipation in real gases and ideal gases?
P.S- I know nothing about half lifes.
Cheers.
Assuming you mean radioactive half lives then classically no there is nothing you can do to the physical conditions to change them.
There has been some work recently that suggests very high pressures can have an effect presumably the nuclei are moved closer together enough that the strong nuclear force can have an effect on a neighbouring atom.
