Hamilton operator with moments of inertia : time - independence
Juqon
The Hamilton-operator is given as \hat{H} and describes the movement of a free rigid object that has the moments of inertia I_{i}
Under what circumstances is
<\Psi|\hat{L_{1}}|\Psi>
time-independent?
\hat{H}=\frac{\hat{L_{1}^{2}}}{2I_{1}}+\frac{\hat{L_{2}^{2}}}{2I_{2}}+\frac{\hat{L_{3}^{2}}}{2I_{3}}
[\hat{L_{j}},\hat{L_{k}}]=\iota\hbar\epsilon_{jkm}\hat{L_{m}}
If it wasn't in the brac-kets, I would just try \frac{dL_{1}}{dt}=0 Also, I thought maybe I could use another picture to have the time-indepence in it automatically, but I think Schrödinger must be the right one as there the operators are constant.
HINT: Remember that the time dependence of the expectation value of an operator, O, is related to: <[O,H]>.
Thanks! I think a found a solution. What do you think about that?
I just need to know whether I can change the indices of the Levi-Civita tensor in a way so that I get a minus in front (other order of the indices) also with operators. If yes, this would not answer the question (see below).
If "otherwise": Is this the end result or can you transform that even more?
[PLAIN]http://img545.imageshack.us/img545/6031/timeindependencemomento.png
No, you cannot switch the indices on the operators and just change the sign to compensate. That would mean the the angular momentum operators anti-commute, which they don't.
You end result is correct(when you don't switch operator indices), but you missed a sign, I think. Your result should be:
\frac{[L_2,L_3]_+}{I_2}=\frac{[L_2,L_3]_+}{I_3}
([A,B]_+ means anti-commutator) or when you simplify:
I_2=I_3
Physically, this means you have an "axially symmetric rotator."You really went about this in the "brute-force" method! There's a much simpler way to get to the same result. You know you are looking for the condition when L_1 and H commute. Now, you also know that you can choose anyone angular momentum operator to commute with L^2. Thus, if you can write H in terms of only L^2 and L_1.
You'll see that this is only possible in two cases: When I_1=I_2=I_3 and when I_2=I_3
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
