How to Determine Current and Tension in Parallel Wires with Repelling Forces
  • Thread starter Thread starter AznBoi
    Hard Magnetism
The discussion focuses on determining the currents in two parallel wires that repel each other due to magnetic forces. Each wire has a mass per unit length of 40 g/m and is supported by strings forming a 16-degree angle. The currents in the wires flow in opposite directions, and the problem can be solved using the equations of motion and magnetic force. By analyzing the forces acting on the wires and using the relationship between magnetic force and current, the magnitude of the currents can be calculated without needing the total weight of the wires.
  • Understanding of magnetic forces and current direction in parallel wires
  • Familiarity with Free Body Diagrams (FBD) for analyzing forces
  • Knowledge of the equation for magnetic field strength, B = μ₀I / (2πr)
  • Basic principles of equilibrium in physics, specifically ΣF = ma
  • Learn how to derive the magnetic force per unit length between parallel wires
  • Study the principles of tension in strings and its relation to angles in physics
  • Explore the concept of mass per unit length and its application in force calculations
  • Investigate the use of unit length in solving physics problems involving forces
Physics students, educators, and anyone interested in understanding the dynamics of parallel wires carrying current and the forces involved in such systems.
AznBoi
Two long parallel wires, each with a mass per unit length of 40g/m, are supported in a horizontal plane by 6 cm long strings, as shown in the figure below. Each wire carries the same current I, causing the wires to repel each other so that the angle (theta) between the supporting strings is 16 degrees.
a) Are the currents in the same or opposite direction?
b) Determine the magnitude of each current
Figure:
\Sigma F=ma
B= \frac{\mu_{0}I}{2\pi r}}
F_{b}=BIl
For a) I know that the current must be in the opposite direction.
For b) I drew a Free Body Diagram first and found that T_{x}=F_{B} and these are the same for both wires. <br /> <br /> <b><u>However, how do you find the tension if they don't specify the exact weight of each wire? They do tell you that each of the wires have "a mass per unit length of 40g/m" but how do you convert that to weight if you don't know how long the wires are? Thanks! </u></b>
Since you know the force per unit length, all you need is mass per unit length to solve the problem.
Can you elaborate on that please? I still don't get how to solve part b) =/
You don't need the total weight of the wires because you can do the whole problem in terms of unit lengths. You know the mass per unit length so you also know the weight (force downwards due to gravity) per unit length. Since the angle is given, you therefore know the component of force per unit length directed between the wires that exactly balances the magnetic force per unit length.
The magnetic force per unit length depends on the current according to the equation you gave,
F_{b}/l=BI.
Eliminate B with your equation for B as a function of I, and solve for I.
