Show: u = x+y2 is Not a Harmonic Function
In summary, the following is not a harmonic function: In summary, the following is not a harmonic function:
andrey21
476
Show that the following is not a harmonic function:
u = x+y2
This is what I know:
du/dx = 1 this must be equal to dv/dy , therefore:
v = y
du/dy = 2y this must be equal to -dv/dx, therefore:
v = -2xy
Putting expressions together:
v = y-2xy.
Not sure where to go from here?
You don't need to compute the harmonic conjugate (the 'v') to check whether a function is harmonic. Just check whether the laplacian vanishes.
So using the following:
d2u / dx2 + d2u/dy2=0
Which for this example gicves:
2+ 0 = 2 so laplacian does not disappear!
Right. So u is not harmonic.
Thanks Dick, I have a similar question which is giving me some problems:
I'm asked to show v = x+2y is part of a harmonic conjugate pair. What is harmonic conjugate pair?
Try to work it out using Cauchy-Riemann, like you were doing before.
Ok so here's my attempt:
v=x+2y
dv/dy = 2 must equal du/dx therefore:
u = 2x
dv/dx = 1 which must equal -du/dy
u = -y
adding together:
u = 2x-y
Am I on the right track??
v=x+2y
u = 2x
u = -y
adding together:
u = 2x-y
Sure. You might be a little more careful of keeping track of things. du/dx=2 means u=2x+f(y) where f(y) is any function of y. du/dy=(-1) means u=-y+g(x) where g(x) is any function of x. When you compare the two expressions you realize f(y)=(-y) and g(x)=2x.
Ok so now I have:
u = 2x-y and v = x+2y
Which can be written as:
2x-y +xi +2yi
andrey21 said:
Ok so now I have:
2x-y +xi +2yi
Ok, so u+iv is an analytic function. Is there more to the problem?
I must find its harmonic conjugate and say what f(z) is.
I thought so. What kind of function does it look like f(z) is, linear, quadratic, exponential??
Im really not sure, I'm pretty sure it isn't a quadratic.
Guess! What kind of function does it look like? What kind of powers of x and y do you see?
exponential?
andrey21 said:
exponential?
Wrong. What kind of powers of x and y do you see in u+iv? Why would you say 'exponential'!?
You have f(x,y)= 2x-y + (x +2y)i; what part of that looks exponential?
Im not to sure what you are asking:
I know that: (x+iy)2 = x2-y2+2xyi
Ok, so in that example you've got z^2 on one side and powers like x^2 on the other. Is that a clue? What about your given function?
So my function will be z on one side?
The highest power of z you would expect to see in f(z) is first power, yes. But that doesn't mean that's all you can have. You could have constants as well. What's the most general form of a linear function in z?
z = f(x,y) = c+mx+my
You want to find f(z). You already know f(x,y). What does a linear function of z look like??
So will it just be c+mz
Sure. f(z) must be m*z+c where m and c are complex. Now try to figure out an m and c so that when you expand into real and imaginary parts it matches your u+iy.
zi +2z
andrey21 said:
zi +2z
Sure, that's it.
Thanks for your help Dick
Related to Show: u = x+y2 is Not a Harmonic Function
1. What is a harmonic function?
A harmonic function is a type of function that satisfies the Laplace's equation, which states that the sum of the second-order partial derivatives of the function with respect to its variables is equal to zero.
2. How do you determine if a function is harmonic?
To determine if a function is harmonic, you need to take the second-order partial derivatives of the function with respect to its variables and then sum them together. If the sum is equal to zero, then the function is harmonic.
3. Why is u = x+y2 not a harmonic function?
This function is not harmonic because when taking the second-order partial derivatives with respect to its variables x and y, the sum does not equal to zero. Therefore, it does not satisfy the Laplace's equation and is not a harmonic function.
4. Can a non-harmonic function be useful in science?
Yes, non-harmonic functions can still be useful in science. They may not satisfy the Laplace's equation, but they may have other properties or behaviors that are relevant to a certain scientific study or application.
5. What are some real-life applications of harmonic functions?
Harmonic functions have various applications in science, engineering, and mathematics. Some examples include modeling the flow of heat or electricity, predicting the behavior of vibrating systems, and solving certain types of differential equations.
