Harmonic Oscillator: Energy Levels Explained
asdf1
why is the energy levels of the harmonic oscillator En=(N+1/2)hf?
Is it derived in your textbook? It's not a particulary short derivation regardless of the method you use do I'd rather not type it out here. As for why the energy levels are like that because that's what you get when you solve Schrödinger's equation for a potential of the harmonic oscillator form.
no it's not derived in my textbook... thank you~
That expression for E arises when solving the Schroedinger Equation analytically using the Power Series Technique (I don't know of any other analytical technique - if anyone else does let me know).
The solution is not hard but it is long.
An easier way to derive E is to use raising and lowering operators.
thank you very much! :)
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
