Harmonic Oscillator: Evaluating Ground State Probability
glebovg
Using the normalization constant A and the value of a, evaluate the probability to find an oscillator in the ground state beyond the classical turning points ±x0. Assume an electron bound to an atomic-sized region (x0 = 0.1 nm) with an effective force constant of 1.0 eV/nm2.
\psi(x)=Ae^{-ax^{2}}, where A=(\frac{m\kappa}{\pi^{2}\hbar^{2}})^{1/8} and a=\sqrt{m\kappa}/2\hbar
How do I find m?
The mass of the electron? You look it up.
or you could weigh one …
if you have one on you o:)
I will try to read the question more carefully next time.
Am I supposed to find probabilities at both tails of the distribution?
Yes.
Apparently there is an inconsistency in the question and there are two interpretations of the question. What would be the other one?
Beats me.
My interpretation: find probabilities at both tails of the distribution i.e. \int^{0}_{-\infty}\psi^{2}(x)\;dx and 1-\int^{0.1}_{-\infty}\psi^{2}(x)\;dx.
I'd say the problem is asking for one number, P(|x|>x0). The upper limit on your first integral is wrong.
Do you mean it is wrong according to your interpretation or it is generally wrong? Should it be 0.1?
It is generally wrong. Why would the upper limit be 0?
It should be -0.1, right?
