Harmonic Oscillator Problem: Energy Levels & Ground State
Metallichem
Problem:
Consider a harmonic oscillator of mass m undergoing harmonic motion in two dimensions x and y. The potential energy is given by
V(x,y) = (1/2)kxx2 + (1/2)kyy2.
(a) Write down the expression for the Hamiltonian operator for such a system.
(b) What is the general expression for the allowable energy levels of the two-dimensional harmonic oscillator?
(c) What is the energy of the ground state (the lowest energy state)?
Hint: The Hamiltonian operator can be written as a sum of operators.
Now I'm a bit lost on how to write the expression for the Hamiltonian.
Is the Hamiltonian simply H = - h2/2m d2/dx2 + V(x,y) [where V(x,y) is given above]?
Then with that Hamiltonian, solving the Schrodinger eqn is pretty straightforward to get H*psi = E*psi, now I'm a bit lost here as well to solve for the general expression for the allowable energy levels?
Metallichem said:
Problem:
Almost. You need to include a term for the kinetic energy due to movement in the y-direction.
Have you solved the one-dimensional harmonic oscillator already?
I can represent the Hamiltonian as a sum of operators like this?
\hat{H} = \hat{H_x} + \hat{H_y}
Yes, depending on what you mean by Hx and Hy.
I get this, this is the general expresion of Hamiltonian Operator for the Quantum Harmonic Oscillator ??
[-ħ/2m (d^2 Ψ_x)/(dx^2 )+1/2 k_x x^2 Ψ_x ]+[-ħ/2m (d^2 Ψ_y)/(dy^2 )+1/2 k_y y^2 Ψ_y ]= EΨ_x Ψ_y
Part (a) is simply asking you for the operator ##\hat{H}##. The wave function doesn't appear in that expression. You wrote in your first post
$$\hat{H} = -\frac{\hbar^2}{2m} \frac{d^2}{dx^2} + V(x,y)$$ which isn't correct, but it's essentially the type of answer you want to give for (a). You just need to correct it, which I think you know how to do.
The Schrodinger equation says what happens when you apply that operator to a wave function:
$$\hat{H}\psi(x,y) = \hat{H}_x \psi(x,y) + \hat{H}_y \psi(x,y) = E \psi(x,y)$$ Note that the two pieces act on the same function. If you assume the solution has the form ##\psi(x,y) = \psi_x(x)\psi_y(y)##, you'll get something similar to what you have. Your expression isn't quite correct. You're getting there though.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
