Has the Higgs Boson Particle Been Discovered at Cern?
  • Context: Undergrad
  • Thread starter Thread starter Maui
    Higgs Particle
The discussion centers around the potential discovery of the Higgs boson particle at CERN, exploring the implications of such a finding, the significance of the results, and the ongoing speculation surrounding the announcement. Participants engage in technical reasoning, speculation about the nature of the particle, and the broader impact on the Standard Model of particle physics.
  • Speculative
  • Some participants express excitement about the potential announcement of the Higgs boson discovery, with references to the significance of the particle in providing mass to other particles.
  • There are multiple speculations regarding the timing of the announcement and the nature of the findings, with some questioning why CERN would delay if they had already confirmed the discovery.
  • Some participants discuss the implications of a 125 GeV mass for the Higgs boson, suggesting it may favor a supersymmetric extension of the Standard Model over a simpler model.
  • One participant highlights the challenges in confirming the properties of the Higgs boson, noting that while evidence suggests it decays to two photons, further analysis is needed to confirm its characteristics.
  • Concerns are raised about whether the observed particle is indeed the Higgs boson or potentially something else, with some expressing skepticism about the certainty of the findings.
  • There is mention of the theoretical implications of the Higgs particle being a fundamental scalar, with discussions on the complexities and challenges associated with scalar field theory.
  • Participants share links to live coverage and updates from CERN, indicating a desire to stay informed about the latest developments.
Participants express a mix of excitement and skepticism regarding the discovery of the Higgs boson. While some seem to lean towards the belief that the findings align with the Standard Model, others question the certainty of the results and the possibility of alternative explanations. The discussion remains unresolved with competing views on the implications of the findings.
There are references to the preliminary nature of the findings and the need for further analysis to confirm the properties of the observed particle. Some statements reflect uncertainty about the validity of the data and the interpretations being made.
Readers interested in particle physics, the Standard Model, and the implications of the Higgs boson discovery may find this discussion relevant.
  • #31
scalar particle means it is not vectorial.. meaning no directions... does it mean it's non-local? is a higgs value say in a pluto identical to the one on earth?
  • #32
In the press conference they talk about determining whether the particle is spin 0 or spin 2, does anyone know why these two particular values for the spin are the discussed candidates? A spin 0 particle would give an isotropic decay guess, how would a spin 2 decay look like, will there be angular dependence (I guess it will) and in that case, how does it look like in detail?
  • #33
I don't mean to derail, but what exactly does it mean to have significance level 5 sigma?
  • #34
It's a confidence level, level five is 99.99994%
  • #35
It's just statistical speak for how accurate the date is more or less. The number of sigma represent the number of standard deviations.
  • #36
Sure, but standard deviations of what?
  • #37
jtbell said:
In other words, it looks like a duck, and it's where we would expect to find a duck (according to the predictions of QAD = quantum aviodynamics), but we have to do further study to verify that it walks like a duck and quacks like a duck.
Maybe you read too much in Zee's book :-)
  • #38
From what little I know about this at present there is a Higgs field which is instrumental in giving particles mass and a Higgs boson which is instrumental in setting up the Higgs field.If this is right then what is instrumental in giving the Higgs boson its mass?:biggrin:
  • #39
Scalar particle means it has spin 0.
  • #40
No, it can vary in space, but it means that it has always the same value at a given point no matter at which angle we look at it.
This is not a case with a photon for example. We could construct an instrument for detecting photons that depend on an angle. I.e. a polarizer. We detect photons when a polarizer is set at some angle and do not detect them when it is rotated by 90 deg. It is impossible to obtain such a polarizer for scalar particles and this is the very definition of a "scalar".
  • #41
That might be why they call it "The God's particle" :smile:
  • #42
Any signal in any experiment could, in principle, be only a statistical fluctuation, an error. Nothing is absolutely certain. The number 99.99994% measures how certain they are that it is NOT an error.
  • #43
I also saw the following formulation:
CMS observes an excess of events at a mass of approximately 125 GeV[2] with a statistical significance of five standard deviations (5 sigma)[3] above background expectations. The probability of the background alone fluctuating up by this amount or more is about one in three million.
[2] The electron volt (eV) is a unit of energy. A GeV is 1,000,000,000 eV. In particle physics, where mass and energy are often interchanged, it is common to use eV/c2 as a unit of mass (from E = mc2, where c is the speed of light in vacuum). Even more common is to use a system of natural units with c set to 1 (hence, E = m), and use eV and GeV as units of mass.
[3] The standard deviation describes the spread of a set of measurements around the mean value. It can be used to quantify the level of disagreement of a set of data from a given hypothesis. Physicists express standard deviations in units called “sigma”. The higher the number of sigma, the more incompatible the data are with the hypothesis. Typically, the more unexpected a discovery is, the greater the number of sigma physicists will require to be convinced.
The BBC news article has the following descriptions:
  • Particle physics has an accepted definition for a discovery: a "five-sigma" (or five standard-deviation) level of certainty
  • The number of sigmas measures how unlikely it is to get a certain experimental result as a matter of chance rather than due to a real effect
  • Similarly, tossing a coin and getting a number of heads in a row may just be chance, rather than a sign of a "loaded" coin
  • A "three-sigma" level represents about the same likelihood as tossing eight heads in a row
  • Five sigma, on the other hand, would correspond to tossing more than 20 in a row
    Independent confirmation by other experiments turns five-sigma findings into accepted discoveries
So, I guess, the sigma refers to fluctuation in the background number of events.
But, how did you come up with the number 99.99994% in relation to 5 sigma?! Also, how did the BBC come up with their numbers of 8 heads in a row for 3 sigma, and 20 heads in a row for a 5 sigma?
  • #45
That would be the probability from -5 to 5 in a standard normal distribution. [itex]N(0,1)[/itex]
  • #46
Raekwon said:
But, isn't the number of background events following a Poisson distribution?
Also, the probability of getting k heads in a row follows the distribution:
[tex] P_k = \frac{1}{2^k}, \ k = 1, 2, \ldots[/tex]
  • #47
As different situations have different distributions, "5 standard deviations" is a bit sloppy. The real meaning is "with background only [no higgs], observing so many events is equally unlikely than getting a value >=5 standard deviations away from the mean in a gaussian distribution".
Vorde said:
ATLAS and CMS have a 99.9999% certainty that there they have found a new boson with a mass of 125 GeV- consistent with the Higgs.
No, and this contains a very fundamental error.
You can never measure "the consistent that you found a particle". You can just give the probability that the measured signal occurs as a random fluctuation (and the probability that this signal occurs if there is a particle).
Simple example: Look for new particles at 1000 different places. Just by chance, you will expect at least one 3sigma-discovery, even if no particle is there at all. Are you 99,7% sure that you discovered a new particle? I hope not.
Particle properties are assumed to be the same everywhere (and up to now, no variation was found). This is independent of the spin.
A scalar field can depend on spacetime. As a simple example: Temperature is scalar, and it is different on pluto.
  • #49
Okie. For a while there. I thought the higgs boson is the carrier of quantum non-locality or connected to it. But then, what's proof it is not connected...
  • #50
No. Since you claim something completely unfamiliar to the rest of us, it is up to you to prove that it is.
  • #51
Echoing Dickfore's question: what do all the sigmas mean? For example, Cosmic Variance at one point says 4.9 for a SM Higgs. But if the particle is a non-SM Higgs, then surely this value must decrease?
BTW, are any papers out yet?
  • #52
This is wrong. 4.9 sigma for "there is something". And measurements indicate that this "something" looks like a Higgs boson.
Concerning the meaning of the number, see the previous page (at 16 post per page*)
*interesting, the option to change this seems to be disabled in this board
  • #53
I think some have referred to it as the goddam particle.Anyway,does anyone know what gives the Higgs particle its mass? If it's not a silly question a reference where I could look it up would be nice.
  • #54
The mass of the Higgs particle is 'created' by two parameters in the Lagrangian
  • #55
Higg's Discovered?
http://news.yahoo.com/scientists-unveil-milestone-higgs-boson-hunt-044513533.html
First off, how do you "observe" a higg's boson? They don't emit light, make sound or conduct any sort of electricity, it's impossible to observe them with any human senses in any way. Then, the article doesn't even explain "how", it just explains "oh yeah trust it's not something else, it's just w/e we said it is". Even if you have a pattern in a particle collision like a particle swirls around a point where we don't observe something, how do we know that point is the unknown particle predicted?
And then on top of ALL of that, what about Einsteins theories? How does it explain frame-dragging? What about space-time curvature? What about conversion of mass to energy?
  • #56
So why does it go up above 5 sigma for some combination of channels and then down to 4.9 for some other combination?
  • #57
Maybe because of look-elsewhere effects, is the parameter space of the data different?
http://en.wikipedia.org/wiki/Look-elsewhere_effect
  • #58
I would assume this is because of the decays into γγ or ZZ - these are spin 1 particles so I think the total spin can be either 0 or 2.
Something I certainly don't understand is the ZZ decay mode, as 2 x MZ > 126GeV. I noticed the slides actually describe the mode as ZZ* - what does that actually mean?
  • #59
So that would mean the CMS 5 sigma from the combination of 2 channels is illegitimate, as is the 5 sigma from ATLAS, since that seems not to have used all the relevant channels?
  • #60
Is there a video of the conference online ?
  • · Replies 17 ·
  • · Replies 38 ·
10K
18K
  • · Replies 42 ·
