Having some trouble interpretting several problems (link fixed)
  • Thread starter Thread starter EasyStyle4747
The discussion revolves around interpreting math problems that the user finds confusing, particularly due to a lack of understanding of math terminology. The user seeks clarification on several specific problems related to finding equations, areas, and distances in relation to a semicircle and a rectangle. Respondents provide guidance on how to approach these problems by suggesting methods to express coordinates and areas as functions of x. They emphasize using known equations and geometric principles, such as the Pythagorean theorem, to derive necessary values. Overall, the conversation highlights the importance of breaking down complex math concepts into simpler terms for better comprehension.
EasyStyle4747
HI, i previously posted this message but i think someone took it off because my link doesn't work. Try it now. Copy and paste this if the link don't work
this:http://www.freewebs.com/easystyle4747/math1%20copy.jpg
thats the link to some questions that I don't quite understand. The thing is, I'm horrible at math terminology, so i have no idea what those things are even asking me to do. My teacher spent all of class explaing the second half of my homework and so i don't know how to do these problems. I have much more problems than those, but those are one of each type. You don't have to give me the answer, infact, i don't want you to. Someone just help me explain those problems as thoroughly as possible. And please don't use too much math terminology because i don't really understand too much of it.
i duno wat is wrong, but if u click the link it takes you right back here. U have to copy and paste it for it to work.
Link works if you copy and paste.
For 66: find equations for p and h that have x as the variable
70: You can deduce the x-coordinates of the points of intersection of the rectangle and semicircle from the diagram. From there, you should be able to find the length of the short side of the rectangle, and thus calculate the area.
73: Hint: you know speed = distance/time.
74: Visualize the circle (disk) formed by the line segment when it is revolved. You know that A = πr². So you need to find the length of the radius in terms of x...
OK, i still have some issues with each of these, and like i said, i my teacher hasnt explained any of these yet.
66. So i assume u mean to find the equation for the line p and h right? But how do you do that? how do u find the equation between that point on the curved line and the x-axis?
70. Well, i can easily find the area in numbers. But express as a function of x? What do i needa do?
73. I still dunt understand the figure. Are we supposed to find the shortest point from the start to destination or are we suppose to follow the dotted path they give us? And, again, the express as function of x thing again. How does that kick in?
74. Again, how do you solve the distance between a point on the curve and the x-axis (aka in this problem, the radius) ?
Thanks for the tips, but please enlighten me some more.
66: OK, find the coordinates of the point of intersection between h and the circle in terms of x only (hint: if the x-coordinate is x, what is the y coordinate -- use the equation)
70: Sorry, I was wrong here. Use the same approach as 66. The x-coordinate of the point of intersection is given to you as x...what is the y-coordinate? You should be able to get the area from there.
73: You follow the hypothenus of each triangle. Find the length of each hypothenus using Pythagorus. For each segment, you have the speed and the distance, so you should be able to find time (in terms of x because you used lengths in terms of x to calculate the length of each hypothenus).
74: You must understand that the y-coordinate of a point on a function is its vertical distance fromt the x-axis. If the coordinates of a point are (x, y), use the same technique as 66 and 70 to find the y-coordinate (from eqn.) and use that to find the area of the disc.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
