Having Trouble With Dipole Torque and Work
The discussion focuses on calculating the torque and work associated with a dipole in an electric field. The dipole moment is given as 2.5 nC·m, and the electric field strength is 3.6 MN/C, with the dipole oriented at 33 degrees. The user struggles with the torque calculation using the equation T = pE sin(theta) and misinterprets unit conversions, leading to incorrect results. For the work required to rotate the dipole to an antiparallel position, the user applies W = -pEcos(theta) but needs to consider the change in potential energy to find the correct work value. Clarification on unit conversions and the distinction between torque and potential energy is essential for accurate calculations.
ccelt09
There is a two part problem that I'm struggling with.
1) A dipole with a moment of 2.5 nC . m is oriented 33 degrees from a field with strength 3.6 MN/C.
What is the magnitude of the torque on the dipole? ____ mN . m
I know the equation T = qd x E sin (theta) where qd is the given dipole moment, but even with converting and plugging in I don't get the right answer.
2)How much work is required to rotate the dipole until it's antiparallel to the field?
again i tried plugging into -pEcos(theta) but my answer is wrong.I am not quite sure why my approach isn't working or what I am doing wrong. I would greatly appreciate any help.
Show what you did so we can see what went wrong.
I used the equation torque = dipole magnitude x E. the dipole came in units 2.5 nC . m, the field as 3.6 MN/C. I took the n to represent nano ^ -9 and M as Mega ^ 6. I did the appropriate conversions to have the product of the two come in units mN.m in which the program wants the answer.
2.5x10^6 mC.m x 3.6x10^6 N/C = 9x10^12 mN.m
2.5 nC x 10^6 to get to 2.5 mC . m and 3.6MN/C x 10^6 to get N/C. I feel that was probably a misinterpretation of what the units represent.
For the second part in order to find the work necessary to make the dipole antiparallel to the field i used W=-pEcos(theta)
-2.5x10^6 mC.m x 3.6x10^6 cos(57) = -4.9x10^12 ; already angled at 33 degrees, 57+33=90 = antiparallel/perpendicular
You're messing up the units a bit:
2.5 nC . m = 2.5x10-6 mC.m (not 2.5x10+6).
That equation tells you the potential energy, U = -pEcos(theta). To find the work, figure out the change in PE.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
