Heat Absorbed to Melt Ice & Warm Water to 10°C
  • Thread starter Thread starter Sabres151
    Heat Ice
To determine the heat absorbed by a 4.00 kg block of ice transitioning from -20°C to water at 10°C, three energy calculations are necessary: heating the ice, melting the ice, and heating the resulting water. The first and third calculations utilize the specific heat capacities of ice and water, respectively, while the second involves the latent heat of fusion, which is the energy needed to melt the ice. The specific heat capacity of ice is 2000 J/kg°C, and for water, it is 4180 J/kg°C, with the latent heat of fusion at 335,000 J/kg. Understanding these concepts is crucial for accurately calculating the total heat absorbed. The discussion emphasizes the importance of these energy calculations in thermodynamics.
Sabres151
A 4.00kg block of ice is removed from a freezer where its temperature was maintained at -20C. Find the heat that the ice must absorb in order to warm up to its melting point, melt, and then the water warms up to 10.0 degrees. The specific heat capacity of ice = 2000J/kg-degrees C, the specific heat of water is 4180 J/kg-degrees C and the latent heat of fusion for ice is 335000 J/kg.
I don't even know where to start.
Something with this: Q = Cm(delta T)
DeltaT = 30 degrees C
you need a 3 energies -
one to heat the ice
one to melt the ice
one to heat the water
th first and third are calculated the way you state (but with different speicifc heats, since they are different for water and ice)
the second is calculated by mass * specific heat capacity
one to heat the ice
one to melt the ice
Ok, that clarifies a few things then. Thanks for the help Stunner. Though I'm not exactly sure what "latent heat of fusion" means, I think it applies to the mass equation..
one to heat the ice
one to melt the ice
one to heat the ice
one to melt the ice
latent heat of fusion is the amount of energy required per kilogram to melt the ice
