Heat equation - theta function?
Gekko
du/dt=d2u/dx2
Show that u(x,t)=(t^a) * theta(xi) where xi=x/sqrt(t) and a is a constant, then theta(xi) satisfys the ODE
a*theta - 0.5 * xi * dtheta/dxi = d2theta/dxi2
Not sure how to start this. Any help most appreciated
(sorry if question isn't easy to ready)
Have you tried the obvious? Put u(x,t)=(t^a) * theta(xi) into the given equation. Since theta(xi) is the only unknow function the result will be an equation in theta.
theta(xi) = u(x,t) / t^a
dtheta/dxi = 1 since the right hand side is just a constant wrt xi so this can't be the approach because it won't satisfy the ODE right?
If the RHS were a constant, the derivative would be 0, not 1. But it's not constant, so it's not relevant.
The idea is to plug in your expression for u(x,t) into the differential equation:
\frac{\partial}{\partial t}[t^a \Theta(\xi(x,t))] = \frac{\partial^2}{\partial x^2}[t^a \Theta(\xi(x,t))]
where \xi(x,t)=x/\sqrt{t}. You'll need to use the chain rule to express the derivatives with respect to t and x in terms of the derivative with respect to ξ.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
