Heat loss and thermal equilibrium of underground aquifer
Ortix
I am working on a project where I have to design and size an aquifer. There are two which either store hot or cold water for 6 months which is then pumped up to be used in either the summer or winter.
The aquifer is going to be 80 meters under the ground. The rest is basically variable. I made the assumption that it's a rectangular cube with (HxWxL) 10x40x20.
The equation I am using is q=λ*A*ΔT/s (i will learn LaTeX eventually ;) )
where lambda is the thermal conductivity of the soil which is 3.44. The temperature difference is 4K where the soil is 11C (constant over time) and the water is 15C. "s" is the thickness.. well the top soil layer is 80m and assumed to be homogeneous with the same thermal conductivity throughout.
But this obviously can't work because the temperature of the water decreases over time so I would need a differential equation but I have no idea how to set this up.
So the question basically boils down to the following two:
1. How do I calculate the end temperature of the water after 6 months
2. When is temperature equilibrium reached
Thing is that all this soil crap is not in my curriculum but my project group ended up with an aquifer to design so we have to do these calculations.
EDIT:
I found this:
http://ec.pathways-news.com/Text-PDF/Part B-6.pdf
And figured I could use equation 6.9
Is that correct? If so what are V and c in that equation?
Homework Equations q=λ*A*ΔT/s The Attempt at a SolutionFor the first part of the question, you can use a differential equation to find the end temperature of the water after 6 months. The equation would look something like this:dT/dt = -(q/(V*c))Where q is the heat transfer rate, V is the volume of the aquifer, and c is the specific heat capacity of the water. This equation can then be solved using standard numerical methods, such as Euler's method or Runge-Kutta integration.For the second part of the question, temperature equilibrium is reached when the rate of heat transfer is equal to zero, which can be determined by setting the left side of the differential equation equal to 0 and solving for T.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
