Heat loss due to Evaporation in a closed environment
The discussion centers on the temperature dynamics within an incubator/shaker for laboratory use, specifically addressing concerns about heat loss due to evaporation in a closed environment. Users clarify that while latent heat is involved in the phase transition from liquid to vapor, the actual heat loss is minimal and primarily affects fluid volume rather than overall temperature. It is suggested that temperature measurement should focus on the water inside the flasks rather than just the air temperature, as water's heat absorption and release are slower. The conversation also touches on the potential for temperature gradients within the chamber due to varying heat sources. Ultimately, the consensus is that while evaporation may be mentioned in the manual, its impact on overall temperature is negligible.
kinga
I am working on an incubator/shaker for laboratory use. I am trying to work out a temperature failure and repair it, but that is besides the point here. I was looking through the user manual to try to get some clues about the failure and I came across this:
"Depending on various conditions within the chamber, such as flask placement and size, the heat produced by growing organisms, heat losses due to liquid evaporation from flasks, etc., the display temperature may differ from temperatures within the flasks themselves. "
I was confused by the idea that there can be heat loss due to evaporation inside a closed environment where everything within this unit is set to the same temperature for hours at a time. The point of the incubation unit is to warm everything up to a set point and hold it there for a set period of time. If the water in the flasks and the air around it is at a uniform temperature (37c) it seems that the heat energy would not be lost due to evaporation but simply moved around the closed chamber. Am I missing something?
thanks
-Kinga
Science news on Phys.org
I don't know much about incubation chambers, but probably the heat loss you described is the so called "latent heat": Some energy is needed during the phase transition from liquid to vapor. This energy is not lost, but it is given back when the vapor turns to liquid again. Did I answer the question?
Thank you for your fast response.
That does make sense, but it seems that there would not be an appreciable amount of heat loss in the rest of the fluid when the water changes states. This unit measures the temperature with a +/- .5 degree error margin, so the small amount of heat that is drawn away during the phase transition would be extremely small, therefore negligible. It seems like the only loss would be in fluid volume within the flask because the vapor would condense on the inside surface of the incubator and not return to the flask (the flasks are open to the chamber air).
I guess my question is:
Why would the manufacturer add the heat loss due to evaporation as a factor, if the effect is so negligible as to not really mater in the overall chamber temperature?
As I told you, my little knowledge allows me to make hypothesis, nothing more. I imagine that you set a certain temperature, and a system of lamps/resistances together with a thermometer sets up a feedback mechanism that maintains that temperature... You say that in equilibrium conditions the temperature must be uniform, but maybe in presence of heat sources/wells this equilibrium is constantly disturbed, so that a gradient of temperature is always present, even if there's the feedback system. And it may happen that temperature measured in the location the thermometer is is different from that under an egg, for example. Every system has a certain relaxation time to reach equilibrium, and if the characteristic time of disturbances isn't long enough respect to the relaxation time, transient phenomena will occur.
Maybe I said a lot of stupidities... in that case I'm sorry.:rolleyes:
That does make sense. I think also that with a full incubator, with several liquid filled containers all fluctuating slightly in temperature as the heaters cycle, will collectively remove heat from the rest of the liquid constantly. The vapor leaves the flasks and condenses on the cooler walls of the windows, so heat is not returned to the flasks. An incubator must be calibrated by measuring water temp inside the unit instead of just air temp. It is a slow process because of how slowly water absorbs and releases heat in comparison to air. The amount of heat lost by the transition to vapor is small and most likely doesn’t really matter, but the author must have wanted to sound like he had all his bases covered. I am going to have to just settle for that.
Your responses were very interesting and well thought out. I appreciate your input. You did help to answer my question.
thank you
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
