How do I calculate the heat sink value for this MOSFET design?
In summary, the heat sink needs to have a rating of 0.4 degrees Celsius per watt, the device it will be cooling needs to be rated at 240 watts, and the ambient temperature needs to be 40 degrees Celsius.
sayeen
Hi, i want to design a heat sink for following mosfet
http://au.element14.com/vishay-formerly-i-r/irfp360pbf/mosfet-n-400v-23a-to-247ac/dp/8649359
its technical data sheet is provided here
http://www.irf.com/product-info/datasheets/data/irfp360.pdf
i am not sure how to design it...by design i mean just the mathematical value for C/W not schematic.
i read somewhere that the formula for finding the value for heat sink is (Tmax - Tamb)/Pd
the ambient temperature is 40C
from my calculation i found the heat sink value to be (150-40)/(280) = 0.4 C/W...is this correct...i located the value for Tmax and Pd (power dessipated) from the datasheet. Is this correct? please any help is appreciated.
I did a Google Images search on the package and added the word heatsink, and got lots of good images. Maybe follow some of the picture links to get to websites with more information on heatsinks for that device package:
http://www.google.com/search?hl=en&...source=og&sa=N&tab=wi&ei=i5Z0UKyfK8mUiAKKg4FA
Thanks, but i am looking for the ratings of the heat sink first...i want to confirm if 0.4C/W rating for the heat sink is correct.
No, you are not approaching this correctly. Look at the datasheet where it lists the Rθ_JC and Rθ_CS. What do they add up to? And that doesn't include the heat sink's Rθ_CA (case to air). And you are not going to run that part at 280W, if that's what you are implying in your previous post.
What real power level are you planning on running this FET at? What is the application? Do you have forced air available to blow over the heatsink?
You should google Heatsink Tutorial, and you will get some very good hits, including ones at heatsink manufacturers and also at FEA software vendors like COMSOL. To "design" this heatsink, you can either look at what is available for that package already (and see what their values of Rθ_CA are, or you can use COMSOL or ANSYS or some other FEA software package to do the thermal simulations...
Hello Sayeen:
The Basic formula you are looking for is Tj = T Ambient + (Rth(total) ( Rth(j-c) + Rth(c-s) + Rth(s-a) ) * Watts Loss) Sorry hard to show in text. th-theta ... Rth thermal resistance, j=junction, c=case, s=sink, a=ambient.
So you can rearrange to get an Rth needed for the Heatsink. Your basic formula is the right idea not not complete & you come up with Rth of 0.4 Deg C/W needed. You are not including the Heatsink - so the device's rating of 0.45 C/W ( Rth(j-c)+Rth(c-s)) is really the result of your calculation.
Berkman is correct - you will NEVER get 240W loss "out of" this device - that data point is at Tcase of 25C ( a standard measurement point for comparing devices - but essentially never a real applicable rating) . However if your converter is 240W and you are 95% efficient, then you have 12W Loss Possible - so you NEED to know what you LOSSES will be in Watts.
TO make an effective heatsink will not be as easy as it seems. I would first go to Newark's website This is a TO-247 Case - and search for TO-247 and HeatSink - they have a bunch for Wakefield ( Wakefiled also has a lot of good info on their site) - for Natural Convection ( no fan) these run 3-15 C/W -- and if you notice these ratings are often expressed as Temp C @ 6W ( I take that to mean that is a typical level of heat these will see w/out a fan is in the 6W range !) With a Fan N you get a 3 to 10X improvement - depending on the design. (I know you may want to do this yourself - but a real HS at $5 or less will be very hard to beat and less than the cost of the MOSFET)
So try to estimate your Losses first - but note an accurate number will not be available until you use a REAL Heatsink Rth. Once a HS concept or ballpark is determined you will need to go back over the calculations - all of the values are interrelated ( The higher the temp the higher the losses - I always start with Tjmaz 125C ( unless a newer 175C rated device - then 150C). - I refer to this as my design limit. Estimate losses, Tambient, NAtual, Fan or Liquid cooled - pick a "typical" heatsink and look at the result. You can "add silicon" as we say reducing losses with bigger, better or more devices, or add cooling with bigger better heatsinking.
Thanks for the info Berkman and Windact...Thermodynamics is not really the field of my study so i got lost there a bit...but you cleared it up..i will try to follow your advice...I will try to calculate Rth for sink by following the formula you have provided...I understand i can ask any local vendor regarding the info for the heat sink for a particular MOSFET...but I have made it a point to do it all by myself! Thanks again
1. What is a heat sink and why is it important for Mosfet design?
A heat sink is a passive cooling device that is used to dissipate heat away from electronic components, such as Mosfets. It is important for Mosfet design because these components can generate a significant amount of heat, which can affect their performance and lifespan if not properly managed.
2. How does a heat sink work?
A heat sink works by increasing the surface area of the component it is attached to, allowing for more efficient transfer of heat to the surrounding air. It also utilizes fins or other designs to increase airflow and aid in heat dissipation. Some heat sinks also have thermal conductive materials, such as copper or aluminum, to help transfer heat away from the component.
3. What factors should be considered when selecting a heat sink for Mosfet design?
When selecting a heat sink for Mosfet design, some important factors to consider include the power dissipation of the Mosfet, the ambient temperature of the environment it will be used in, the available space for the heat sink, and the thermal resistance of the heat sink itself. It is also important to ensure that the heat sink is compatible with the Mosfet's package and mounting method.
4. Can a heat sink be too big for a Mosfet?
Yes, a heat sink can be too big for a Mosfet. While a larger heat sink may have greater heat dissipation capabilities, it can also add weight and cost to the design. It is important to select a heat sink that is appropriately sized for the specific Mosfet and its operating conditions.
5. Are there any alternative cooling methods for Mosfet design?
Yes, there are alternative cooling methods for Mosfet design. Some of these include active cooling methods such as fans or liquid cooling systems, as well as phase change materials or heat pipes. However, these methods may be more complex and expensive compared to using a heat sink, so it is important to carefully consider the needs and constraints of the specific Mosfet design before choosing an alternative cooling method.
  • Mechanical Engineering
  • Electrical Engineering
16K
11K
