Heat transfer - will my lipstick formula melt in the storage package?
The discussion focuses on the stability of lipstick at 50ºC, specifically whether the lipstick will reach that temperature in its packaging. It is noted that while the packaging provides some insulation, the lipstick will likely approach 50ºC over time, although it may not reach it immediately due to heat transfer dynamics. The melting point of the lipstick is crucial, as it needs to be higher than 50ºC to avoid melting, especially since the current formula has a melting point of 40-45ºC. The challenge lies in formulating a lipstick that maintains a desirable soft texture while ensuring it remains stable at higher temperatures. Ultimately, testing the lipstick in an oven for an extended period is suggested to determine its stability.
Makeup Chemist
Hi, I am a makeup formulator and need to make a lipstick that would be stable at 50ºC.
The stability is tested in a chamber with an inner temperature of 50ºC.
The lipstick is in a plastic packaging - a regular one that can be seen in any store.
The question is: Will the temperature of the lipstick itself reach 50ºC?
Would part of the heat get "stopped" by the packaging and the actual lipstick would actually get heated to less than 50ºC? I vaguely remember from uni that coefficient of heat transfer and that there was some loss of temperature down the line when it reaches the final object?
The whole objective of the experiment: even if the melting point of the formula is 48-49ºC, that does not necessarily mean that the lipstick bullet will melt over at 50ºC into its packaging.
Any thoughts please, and thank you!
Science news on Phys.org
Hi
welcome to PF :smile:
I would say most likely
If it is less, probably only a few deg's less ... consider a "TV dinner" in its packaging and put into an oven ... there's no problem heating it upDave
Yes, it will reach 50ºC if you leave it long enough. The package will insulate it to some degree, which means it slows down the rate of warming. How much and how long you need to leave it is difficult to say and probably best determined by experiment.
Even if you put an object in the oven with no insulation, it will take time for heat to be transferred and the temperature to rise. The rate of heat transfer will be propotional to the temperature difference between the object and its surroundings. If the oven is at 50ºC then the temperature of the object (lipstick) will approach 50ºC asymptotically - ie. theoretically it takes for ever! But the oven won't be at exactly 50ºC all the time, so you will get to the lower bound eventually.
The other factor is that, if the MP were 50ºC, then it will not melt immediately it gets to 50ºC. You need to continue supplying heat to change the state from solid to liquid. But probably it doesn't have a clear melting point, but melts over a range of temp.
All in all, I'd think your oven should be a few degrees warmer than your expected MP. If it warms slowly and you take the lipstick out when it has half melted, then it will be at its mid MP even though the oven is warmer.
If you can measure and graph the temperature of a sample as it warms or cools, the flattening of the slope will indicate the melting range. (This could be a sample in a test tube or something. The package is irrelevant here.)
If you just want to know if the lipstick is ok up to 50ºC, pop it in the oven and leave it for a week. If it's not deformed by then, I'd guess you're safe.
But this is just based on my limited experience of finding MPs in an ordinary chem lab. There must be a history of this sort of testing amongst your industry. Try to find someone versed in the art.
Likes nasu
Thank you so much!
Actually few degrees means A LOT in our world. So if the bullet stays at 48-49ºC, that would be all we need.
Wow Merlin 3189, you are so knowledgeable, I admire that! I can definitely put the lipstick in the oven and I do it regularly with every new formulation.
Now I have to act the other way around. My current formula melted since its melting point is 40-45ºC and that is because our client requested this soft texture.
It's a new trend with lipsticks.
So I have to strengthen the bullet to not melt at 50ºC, but keep the nice texture. It's quite challenging.
The problem is what melting point to target? I was hoping that m.p. of 48-50ºC would be fine.. I was hoping that the bullet doesn't reach exactly 50ºC.
Yes, the duration is at least 1 week.
Thank you!
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
