Heated air below mercury pushes it out of glass tube
The discussion revolves around a vertical glass tube filled with an unknown gas in the lower half and mercury in the upper half. The problem involves determining the temperature to which the gas must be heated in order to push the mercury out of the tube.
  • Participants discuss the relationship between pressure and temperature, with some questioning the use of negative pressures in the equations presented. There is also exploration of the maximum temperature and pressure required to initiate the expulsion of mercury.
Participants are actively engaging with the problem, offering insights into the behavior of mercury and gas under varying temperatures and pressures. Some have suggested considering intermediate positions of the mercury column, while others express uncertainty about the stability of the system and the implications of the initial conditions.
There are concerns regarding the physical stability of the system, particularly the state of mercury at room temperature and its freezing point. This raises questions about the assumptions made in the problem setup.
marcbodea
vertical glass tube with height of 2H. H is 760mm.
the lower half is full of an unknown gas. the upper half is full of mercury.
The gas gets heated so it pushes the mercury out of the glass tube.
What temperature must the gas be heated to?
here is the photo if, for some reason, it doesn't show up http://i.imgur.com/p1H9YyR.jpg
## p_1 = -p_0 - \rho h g ##
## p_2 = -p_0 ## because tube doesn't have mercury
## h = H = 760 mm ##
## \rho h g = 10^5 Pa##
## \frac{p*V}{T} = ct ##
## \frac{p_1*V_1}{T_1}=\frac{p_2*V_2}{T_2} ##
## \frac{p_1*V_1}{p_2*V_2}=\frac{T_1}{T_2} ##
## \frac{(-p_0 - \rho h g) S H}{(-p_0) S 2 H} = \frac{T_1}{T_2} ##
## \frac{-p_0 - \rho h g}{-2p_0} = \frac{T_1}{T_2} ##
## \frac{p_0+ \rho h g}{2p_0} = \frac{T_1}{T_2} ##
but ## \rho h g = p_0 ##
so ##\frac{T_1}{T_2} = 1 ##
and ## T_1 = T_2 ##
Hello and welcome to PF!
Why are the pressures negative?
3. The Attempt at a Solution
and ## T_1 = T_2 ##
The negative signs that you had in the pressures cancel out, so your answer for ##T_2## is correct (when the last bit of mercury is expelled).
But, you need to consider the temperatures required at intermediate positions of the mercury column.
Thank you. Here is the explanation:
im sorry, i got it wrong. it was something like this ## p_1-p_0-h\rho g = 0## , so ## p_1=p_0 + \rho h g ##
TSny said:
The negative signs that you had in the pressures cancel out, so your answer for T2T_2 is correct (when the last bit of mercury is expelled).
I'm thinking that the max temperature and pressure are at the initial point, when the gas has to push the biggest amount of mercury.
Initially, the temperature will need to be increased in order to push some of the mercury out of the tube. So, the max temperature is not the initial temperature.
yes, sorry, I'm really tired. That's what i meant to say, that the max temperature and pressure are the temperature and pressure at the point that the gas starts pushing the mercury
I'm not sure what the point of this exercise is. Mercury is a liquid at room temperature and freezes at temperatures below -39° C. Unless the initial temperature of the tube is such that the mercury has solidified, the situation with liquid mercury over gas is not stable. The liquid mercury is going to wind up in the bottom of the tube, with the gas on top.
Yes. I guess it's just an academic exercise. They should have included a thin, massless piston at the bottom of the mercury.
Anyway, I thought it was kind of interesting to work through.
I think you will find that the max temperature occurs at a point where quite a bit of mercury has been pushed out.
Thank you for all the help, but I can't tell when the temperature will reach it's max value. I've tried to do something like ## T=max <=> p V =max## , but I didn't get anywhere..
Suppose that some of the mercury has been pushed out so that the height of the mercury left inside the tube is ##h##. Can you find an expression for the temperature of the gas in terms of ##h##?
  • · Replies 21 ·
