What is Jane and Cheetah's Speed Before Grabbing Tarzan?
  • Thread starter Thread starter tandoorichicken
    Kinematics
Jane and Cheetah, with a combined mass of 70 kg, need to swing down from a 10m cliff to rescue Tarzan, who is positioned at 0 potential energy. Using the conservation of energy principle, their initial potential energy of 6860 Joules converts entirely into kinetic energy as they descend. The equation 35V² = 6860 is used to calculate their speed just before grabbing Tarzan. Solving this gives a speed of approximately 14 m/s. This speed ensures they can reach a perch 5m above Tarzan, allowing for a successful rescue.
tandoorichicken
Tarzan is in trouble once again and Jane and Cheetah have to decide whether to try to bail him out. Jane and Cheetah (70kg combined) are perched on a cliff 10m above Tarzan (70kg) and can swing down on a vine and grab him. To get to safety, they need to get to a perch 5m above Tarzan on the other side.
Determine the speed of Jane and Cheetah just before they would grab Tarzan. Assume no air drag or friction.
That should be fairly straight forward if you use "conservation of energy". Take Tarzan's position as 0 potential energy. Since they need to get to a position 5 m above Tarzan, where the potential energy of all 3 is 140g(5)= 700(9.81)= 6867 Joules, their total energy must be greater than 6867 Joules.
You know that the combined mass of Cheetah and Jane is 70 kg. so, taking V as their speed (in m/s) just before they "pickup" Tarzan, their kinetic energy is 35V2 Joules. Since their potential energy is now 0, their total energy is 35V2.
Solve 35V2= 6867.
To determine the speed of Jane and Cheetah just before they grab Tarzan, we can use the equation for conservation of energy. Since there is no air drag or friction, all of the initial potential energy from being perched on the cliff will be converted into kinetic energy as they swing down on the vine.
The initial potential energy of Jane and Cheetah is given by mgh, where m is their combined mass of 70kg, g is the acceleration due to gravity (9.8 m/s^2), and h is the height of the cliff (10m).
PE = mgh
= (70kg)(9.8 m/s^2)(10m)
= 6860 Joules
This potential energy will be converted into kinetic energy, given by the equation KE = 1/2mv^2, where v is the velocity.
KE = 1/2mv^2
6860 = 1/2(70kg)v^2
v^2 = (2)(6860)/70
v = √196 m/s
v = 14 m/s
Therefore, the speed of Jane and Cheetah just before they grab Tarzan will be approximately 14 m/s. This is assuming they have a perfectly efficient swing and all of their potential energy is converted into kinetic energy. If there are any inefficiencies or losses, the actual speed may be slightly lower. But with this speed, they should be able to reach the perch 5m above Tarzan on the other side and save him from trouble.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
