Find the Height of a 90 Degree Notch in a Block of Metal
  • Thread starter Thread starter steadenator
    Height
The discussion revolves around a homework problem involving a block of metal with a 90-degree notch resting on a circular cylinder. The key details include the cylinder's diameter of 2.0 cm and the lower surface of the block being 1.3 cm above the base plane. Participants emphasize the importance of adhering to ethical guidelines by not providing direct solutions to homework questions. They suggest posting in the appropriate Homework Help forum and following specific guidelines to avoid thread deletion. The thread has been moved to the Homework Help forums for further assistance.
steadenator
I have this homework problem:
A block of metal has a 90 degree notch cut from its lower surface. The notched part rests on a circular cylinder of diameter 2.0cm. If the lower surface of the part is 1.3cm above the base plane, how deep is the notch?
I can't think of how to solve it. Any suggsestions would be much appreciated.
Beacuse you yourself say it is homework question, we cannot ethically solve the problem for you. In order to get help with your predicament, you should-
1) Post this in the Homework help forum (a moderator will be happy to move the thread for you): https://www.physicsforums.com/forumdisplay.php?f=158
2) Follow the homework help guidelines to ensure your thread is not deleted: https://www.physicsforums.com/showthread.php?t=94388
Good luck with your assignment.
Thread moved to Homework Help forums. Please show us some of your own work, steadenator, so that we can offer some suggestions...
