Heisenberg Uncertainty Derivation
The discussion focuses on deriving the quantum-mechanical uncertainty in the position of a particle at temperature T, expressed as Δx ~ √(h²/4mkT). Participants explore the uncertainty relation ΔpΔx ≥ h/2 and the kinetic energy equation K.E. = 0.5 mv² = 0.5 kT. An attempt is made to isolate Δx by substituting Δp with expressions involving mass and velocity, but challenges arise in simplifying the equation correctly. One participant suggests using Δp = √(2mE) with E as the kinetic energy, which equals 1/2 kT. The conversation emphasizes the need for further insights to successfully complete the derivation.
XJellieBX
Using the uncertainty relation for momentum and position, show that the quantum-mechanical uncertainty in the position of a particle at temperture T is
\Delta x~\sqrt{\frac{h^{2}}{4mkT}}
where T is the temperature and k is the Boltzmann's constant.
\Delta p\Delta x\geq h/2, h being Planck's constant
K.E.=0.5 mv2=0.5 kT
I isolated \Delta x and subbed \Delta p=mv=kT/v.
So, \Delta x~h/2\Delta p ~ h/2mv ~ hv/2kT.
I've tried subing in a whole bunch of stuff for v but I can't seem to get the equation. Any insight?
K.E.=0.5 mv2=0.5 kT
Delta p[/tex] = sqrt(2mE) where E is the kinetic energy which is equal to 1/2*kT
Thanks =)
