Heisenberg's uncertainity princple
  • Thread starter Thread starter 106267
Heisenberg's uncertainty principle is a fundamental concept in quantum mechanics that states that certain pairs of physical properties, like position and momentum, cannot be simultaneously measured with arbitrary precision. For year 12 assignments, resources such as "Quantum" by Manjit Kumar and Wikipedia's page on the uncertainty principle are recommended for comprehensive overviews. Additional academic papers and discussions, including those by Albert Messiah and Lee Smolin, provide deeper insights into the principle's implications. Forums and lecture series by Richard Feynman may also offer accessible explanations suitable for high school students. These resources collectively help clarify the complexities of the uncertainty principle for educational purposes.
106267
i'm been searching the internet for resources regarding Heisenberg's uncertainity princple for my year 12 assignment, however, have can't find any clear sources. Would someone please suggest a comprehensive sources thank you
What kind of resources do you require? I'm guessing you aren't wanting a derivation from principles of quantum mechanics, but perhaps a more cultural overview?
If that's the case then Quantum, by Manjit Kumar is a good book. Otherwise, have a look on wikipedia under Uncerternty Principle and see what it is you're interested in and follow the references there.
Many sources listed here:
http://en.wikipedia.org/wiki/Heisenberg_uncertainty
[This has a good discussion followed by a lot of references.]
Albert Messiah, Quantum Mechanics, p119
“When carrying out a measurement of position or momentum on an individual system represented by psi, no definite prediction can be made about the result. The predictions defined here apply to a very large number [N] of equivalent systems independent of each other each system being represented by the same wave function [psi]. If one carries out a position measurement on each one of them, The probability density P[r], or momentum density, gives the distribution of the [N] results of measurements in the limit where the number N of members of this statistical ensemble approaches infinity.”
: http://arxiv.org/abs/1008.4591 ]
http://arxiv.org/abs/quant-ph/0609185
http://tf.nist.gov/general/pdf/1283.pdf
http://arxiv.org/abs/arXiv:1104.2822 Lee Smolin
A new ensemble interpretation of quantum mechanics is proposed according to which the ensemble associated to a quantum state really exists: it is the ensemble of all the systems in the same quantum state in the universe…The problem is that Smolin’s real ensemble is non-local.
ZapperZ explains this in his blog Misconception of the Heisenberg Uncertainty Principle.
the eigenstates corresponding to the respective measurement operators are incompatible. As a result, the system cannot simultaneously have both a definite value of qj and a definite value of pj. See Fourier Transforms and Uncertainty for more on this topic.
(mathpages: http://www.mathpages.com/home/kmath523/kmath523.htm)
I'd also suggest you search these forums for discussions where you will find careful dissection about what HUPis and what it is NOT...
Part of the lecture series by Feynman on QED delves into the Heisenberg principle. They have been turned into an accessible set of books by an author, but they are essentially transcripts.
I used them during my A-levels and found it useful
any more specific sources which explain Heisenberg uncertainty principle in a more simple manner? (as in grade 12 standard)
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
9K
