How can I differentiate between alpha particles and helium in an enclosed space?
To differentiate between alpha particles and helium in an enclosed space, a mass spectrometer or residual gas analyzer (RGA) can be employed, as they effectively detect helium by ionizing it for measurement. Measuring pressure can also indicate helium levels if it is the only gas present. For experiments involving alpha decay, a silicon detector can be utilized to identify charged alpha particles. Accurate results depend on having a calibrated measurement device or standard for comparison. Understanding the principles of vacuum technology is essential, and resources like "A User's Guide to Vacuum Technology" by John F. O'Hanlon can provide valuable insights.
connorp
Can someone recommend (if possible) a way to detect the amount of helium in a given enclosed space? I'm designing an experiment in which I will need to measure the amount in an otherwise vacuum.
If helium is the only thing in the container, why not just measure the pressure?
How to detect the amount depends on the quality of the vacuum and the level of helium in that volume.
Normal Helium mass spectrometer/RGA leak detection methods will work and can be fairly accurate if you have a calibrated measurement device or a calibrated leak to use as a standard.
Find a copy of 'A User's Guide to Vacuum Technology by John F. O'Hanlon" for measurement details.
http://www.lesker.com/newweb/Techni...etect_01_Overview.cfm?section=leaks&init=skip
Gas Chromatograph or Mass Spectrometer (RGA)
Oops. Forgot to mention that the experiment would involve the alpha decay of a radioactive source, hence, I need a way to differentiate between alpha particles and helium.
That's out of my level of expertise but to detect helium with a mass spectrometer/RGA you need to ionize it first so it can be accelerated into the mass detector. For charged particles like alphas a silicon detector could be used.
http://www.ortec-online.com/Solutions/RadiationDetectors/silicon-charged-particle-detectors.aspx
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
