Help Applying Norton and Thevin Equivalents
  • Thread starter Thread starter IronBrain
The discussion focuses on finding the Thevenin and Norton equivalents of a circuit, with an emphasis on simplifying the process for beginners. Participants suggest starting with the Norton equivalent and highlight the importance of understanding the circuit's components, particularly when dependent sources are involved. Clarification is provided that the method for finding resistance (R) differs based on the presence of independent and dependent sources. The conversation also notes that the Wikipedia page on Norton's Theorem may contain misleading information regarding the calculation methods. Overall, the thread aims to assist newcomers in mastering these fundamental circuit analysis techniques.
IronBrain
I am to find the Thevin and Norton equivalents of the following circuits, my problem being I am new to these method and any help is appreciated also is there any way to simplify this circuit properly?
Bump...
I suppose their nothing in this circuit that can conflict with finding my solution such as a "trick"
Since you say you're new to these methods, have you worked on simpler problems, like ones without a dependent source? There's generally no trick to solving these problems. You just grind them out.
The Wikipedia page on Norton's Theorem is misleading about how to find R. The page claims you have to use the method of applying a current source to the terminals when there are dependent sources present, but this method is required only when all of the sources are dependent. Your circuit has an independent source, so you can find R by calculating the open-circuit voltage and short-circuit current and finding their ratio.
I think, no one here(including the moderator/administrator) can answer any problem solving related to engineering.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
