Calculating Tension in a Rigid Beam Supported by Three Vertical Rods
  • Thread starter aznboywunder
  • Tags
    Tension
In summary: Yes, that does make the calculation a lot easier by using the equivalent force -couple at mid-span approach.In summary, the beam has a 6000lb load which is applied halfway between the center and the right end. The tension in each bar is 6000x1.25/6 = 300 lbs.
aznboywunder
A rigid weightless horizontal 5ft long beam is supported by three vertical tension rods. Two of the rods are at the ends of the beam, the third one is in the middle. The beam has a 6000lb load which is applied halfway between the center and the right end. Calculate the tension in each bar. All bars are 6ft long and .375" diameter and are made of steel.
I've been on this for an hour now and can't seem to figure out an answer. Is it true that bar 2 and 3 are carrying 3000lbs?
No, that is not correct. This is an example of a rigid beam on elastic supports; the beam can rotate but not deform, and the tension rod supports may be considered as elastic springs. If the middle and right supports each carried 3000 lbs, then the left support would carry no load, which would violate the geometry of the rigid beam rotation.
This is a statically indeterminate problem. You must solve it accordingly, and note the geometry of the beam rotation and corresponding relationship of the rod deflections. The right support carries the larger share of the 6000 pound load, while the left support carries the least share of the load. The middle support carries one half the sum of the left and right support reactions.
I agree with Jay, but there is an alternative approach in this case, which is to 'move' the load to the centre, but also add a moment of 6000 x 1.25. The central load is then shared equally between the three bars, (2000 each) and the outer ones take the moment (6000x1.25/5 = 1500). Then add up the effects separately. Left side is 2000-1500= 500 middle is 2000 right end is 2000 + 1500 = 3500. This appoach is possible because the three rods are the same cross-section.
Please be careful not to do the original poster's (OP's) work for them. We are here to provide tutorial hints, and to find mistakes in their posted work. Please do not work out the equations for them.
Hi. For your alternative solution, you wrote that "the outer ones take the moment (6000x1.25/5 = 1500). Then add up the effects separately." I don't get the calculation part. Can you explain how you came up with this calculation?(6000x1.25/5)
1. What is tension in physics?
Tension in physics refers to the pulling force acting on an object that is supported by a string, rope, or cable. It is a type of mechanical stress that can be measured in units of force, such as Newtons or pounds.
2. How do you calculate tension?
Tension can be calculated by using the equation T = F * sin(θ), where T is the tension force, F is the applied force, and θ is the angle between the direction of the applied force and the direction of the object's motion.
3. What factors affect tension?
The two main factors that affect tension are the magnitude of the applied force and the angle at which the force is applied. Other factors that can influence tension include the properties of the material the object is made of, the length of the string or rope, and any external forces acting on the object.
4. Can tension be negative?
Yes, tension can be negative. A negative tension force occurs when the direction of the applied force is opposite to the direction of the object's motion. This can happen, for example, when a counterweight is used to balance the tension force in a system.
5. How is tension used in real life?
Tension is used in a variety of everyday situations, such as lifting objects with cranes or pulleys, measuring the weight of objects with a scale, and even in activities like rock climbing or bungee jumping. It is also an important concept in engineering and construction, where tension forces are used to strengthen and stabilize structures.
  • Mechanical Engineering
