Finding Center of Mass and Velocity of Three Moving Balls
To find the center of mass and velocity of three moving balls, the positions and velocities of each mass must be accurately defined. Mass A is moving left at 8 m/s, Mass B right at 6 m/s, and Mass C right at 2 m/s, with specific distances between them. The center of mass (Xcm) was calculated as 7 m using the formula Xcm = (mAxA + mBxB + mCxC) / (mA + mB + mC). However, while the position was correct, the velocity calculation (Vcm) initially used incorrect values for the velocities, as direction must be considered (left as negative). The corrected velocity of the center of mass is essential for an accurate understanding of the system's dynamics.
Gisellebarr
Three Balls are moving along a straight line having the instantaneous positions shown in figure 8.15. At that instant, find the location and velocity of the center of mass of this system.
Figure 8.15
Mass A---------------------Mass B-----------------------------------Mass C
Mass A is moving at 8 m/s to the left with mass 2.00 kg
Mass B is moving at 6.00 m/s to the right with mass 3.00 kg
Mass C is moving at 2.00 m/s to the right with mass 4.00 kg
Mass A is 5.00 m from Mass B
Mass B is 7.00 m from Mass C
As simple as this problem is I don't even know where to start! The only thing I understand from the problem is conservation of momentum but I don't know how to apply it to this situation.
This is not a conservation of momentum situation. What is the equation that gives the position of the center of mass of any number of masses? Look it up in your textbook.
Okay I rechecked the book and tried to work out a similar problem
I set the location of each mass on the x-axis with Mass A at 0, Mass B at 5 in the +x direction and Mass C at 12 in the + x direction
I applied that Xcm= mAxA+mBxB+mCxC/ mA+mB+mC= 7 m
To find the location of the center of Mass
Then
Vcm= mAvA+mBvB+mCvC/ mA+mB+mC= 4.67 m/s
To find the velocity of the center of mass.
Is this correct?
The position of the center of mass is correct, but the its velocity is not. Your equation is correct, but you plugged in the wrong numbers. Remember: If something moving to the right has positive velocity, something moving to the left has negative velocity.
Oh! That makes sense! Thanks :)
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
