Help with Circle Geometry Homework - Calculate Co-ordinates of M
  • Thread starter Thread starter DERRAN
    Circle Geometry
To calculate the coordinates of point M, which is the center of a circle containing points A(2,3) and B(-1,6), three equations are needed due to three unknowns: c, d, and the radius r. The standard form of the circle's equation is crucial, and substituting the coordinates of points A and B into this equation will yield two equations. Additionally, substituting the coordinates of M into the line equation 2x + 5y + 1=0 provides a third equation. After working through these equations, the coordinates of M are determined to be (-3,1).
DERRAN
In the diagram alongside, A(2,3) and B(-1,6) lie on the circle with centre M(c,d).
M is also a point on the straight line defined by 2x + 5y + 1=0. The diagram is on the attached doc file.
Calculate the co-ordinates of M.
analytical methods only!
Im really stuck:frown:
You have 3 unknowns (c, d, and the radius r of the circle), so you need 3 equations to find them. Try to answer the following questions. They should help you.
1.) What is the standard form of the equation form of a circle with center (c,d) and radius r?
2.) What do you get when you plug the point (x,y)=(-1,6) into that equation?
3.) What do you get when you plug the point (x,y)=(2,3) into that same equation?
4.) What do you get when you plug the point (x,y)=(c,d) into the equation of the given line?
That should get you started.
Thank you I got it. M is (-3,1):biggrin:
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
