Help finishing a linear differential equation. Mechanics
navm1
Find the distance which an object moves in time t if it starts from rest and has an acceleration d^2x/dt^2 = ge^-kt.
Show that for small t the result is approx "x=(gt^2)/2" and show that for very large t, the speed is approximately constant. the constant is called the terminal speed.
I ended up with v = -(ge^-kt)/k + v_0 and x = (ge^-kt)/k^2 + v_0t + x_0 however I am not sure what to do next. I have tried to solve for k and also set t as zero to get x = g/k^2 but it doesn't seem to be the answer the book is looking for.
Thanks
For small t, look at the Taylor expansion for the exponential.
For large t, take the difference between ##\int_0^{T+\Delta} ge^{-kt}\, dt-\int_0^T ge^{-kt}\, dt ## for large T, or instead of ##T+\Delta,## use ##\infty##.
##k## is a given parameter. You don't want to solve for it.
You might find it helpful to use definite integrals, e.g.,
$$\int_{v_0}^v \,dv = \int_0^t ge^{-kt}\,dt.$$ The problem statement says the object starts from rest, so use that bit of information too.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
