Help for easy electric problems
  • Thread starter Thread starter x-men
    Electric
x-men
A proton with speed v=3 . 10*5m/s , (.=coss) orbits just outside the charged sphere of radius = 1cm What is the charge of sphere?
What, exactly, have you done so far?
