C/C++ Help getting Boost included in my C++ program
The discussion centers around issues related to including the Boost Filesystem library in a project. The user has attempted to modify the Library Search Path to locate the filesystem.hpp file, trying various include directives and search path configurations without success. They are seeking suggestions for troubleshooting the inclusion of the library. Additionally, they provide a guideline for downloading and setting up Boost, which includes checking the installation script for version compatibility, running the script to create the BOOST environment variable, and configuring build settings in XCode. The user suspects that their problem may stem from the need for a separate build for the Filesystem library, indicating a potential oversight in the setup process.
Jamin2112
I've changed the Library Search Path to the folder that contains the file I'm trying to use, filesystem.hpp, and then including the file with the directive #include <filesystem.hpp>. I've also tried changing it to "filesystem.hpp"; changing the search to recursive; trying to grab it from the folder 1 level above in the directory by changing the search path 1 level above and changing the directive to #include <boost/filestysem.hpp>, #include "boost/filestysem.hpp", etc.
Hopefully the following screenshots can show you where I'm at.
Any suggestions about what I can try to fix this?
Likes Silicon Waffle
Technology news on Phys.org
Here is an "imaginary" guideline :DD. Use this with your own risk.
1. Download Boost and extract it into your favorite folder.
2. Check the xxxboostxxx.sh file to see if its version to be installed matches with one you would want to build.
3. Run it ./xxxboostxxx.sh, after which the BOOST environment variable will be created.
4. Create your build settings in XCode (you can use the attachments below then fix the versions of gcc/g++ compiler and boost).
OTHER_LDFLAGS = $(BOOST)/lib/libboost_system-xgcc48-mt-$(BOOST_VERSION)-macosx.a
HEADER_SEARCH_PATHS = $(inherited) $(BOOST)/include/boost-$(BOOST_VERSION)/
LIBRARY_SEARCH_PATHS = $(inherited) $(BOOST)/lib
BOOST_VERSION = 1_57
Done.
It doesn't. Should I change the VERSION variable accordingly?
Am I supposed to use a modified version of that script and is supposed to be self-explanatory which portions I need to modify for my own use?
I may have detected my problem. I'm trying to use the Filesystem library and it says here that Filesystem requires a separate build.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
Thread 'Project Documentation'
Trying to package up a small bank account manager project that I have been tempering on for a while. One that is certainly worth something to me. Although I have created methods to whip up quick documents with all fields and properties. I would like something better to reference in order to express the mechanical functions. It is unclear to me about any standardized format for code documentation that exists. I have tried object orientated diagrams with shapes to try and express the...
