Help Graphing Piece Wise Function Please
  • Thread starter Thread starter GreenPrint
    Function Graphing
To graph the piecewise function y = 3 - x for x ≤ 1 and y = 2x for x > 1, the point (1, 2) is a closed point, indicating that the function includes this value. Since the function is continuous at x = 1, there is no need for an open circle at that point. The graph should show the two lines connected at (1, 2) without any special notation. If the function were discontinuous at that point, an open circle would be used for the part not including the value. In this case, simply plot the two segments as one continuous line.
GreenPrint
Having some trouble graphing this
y = 3 - x for x less then or equal to 1
y = 2x for x greater than one
how do I indicate that for the first part (1, 2) there would be a closed point at that cordinate but for the second part an open point at those same exact cordinates how do I indicate this on my graph?
Well, your function seems to be continuous, so there is no "open circle" for the second part of the function. If, say, y=3x for x > 1, then you would draw an open circle at (1,3) and a closed one at (1,2). But here, you just draw the two lines connected at (1,2).
you do not indicate that. You are plotting the entire function, not its individual pieces. And (1,2) is a closed point for the function.
Let me clarify. When graphing a function that is piecewise continuous but discontinuous at a point, you indicate the function value at the discontinuity with a closed circle on the piece that contains the function value, and an open point on the piece that does not. When graphing the function here, the function is everywhere continuous, and so it is not necessary to explicitly denote the function value at the point where the function is piecewise defined differently with any kind of special circle. You can just draw the two lines connected.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
